Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Sun Sep 18, 2011 7:02 am Post subject: Engine start-up regimen |
Wondering if there's a generally-accepted regimen for the first start-up
of an RV's engine. In my case, it's an IO-360-B1B (from mattituck). I
ask because I noticed on Mr. Checkoway's site that there was a 5-minute
warm-up period (according to his people who were assisting him) and then
he ran it to run-up power, though I'm not sure for how long, nor what
tests -- if any -- he was doing during the run-up, or during the 5
minute-warm-up.
Thanks for any advice.
Also if anyone in St. Paul has a pick-up truck, how 'bout coming out to
KSGS next Saturday and letting me tie an airplane to its bumper?
Do not archive.
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
Kellym
Posted: Sun Sep 18, 2011 7:14 am Post subject: Engine start-up regimen |
You need to define the purpose of your ground run. I do not see any
purpose what so ever in a "warm up" unless you have ambient temperatures
cold enough to require an engine pre-heat.
In general, with a freshly overhauled or new engine you want to only
verify there are no leaks and that fuel and oil pressures are in the
ball park. You do not want to let the cylinders get hot enough for any
oil to glaze on the cylinder walls. You want to shut the engine off as
soon as you verify no leaks and proper pressures. Let it cool
completely. If necessary a second run is okay for same reasons. Once you
have any leaks fixed and oil pressure where it belongs, any further
ground run just increases the chances of glazing cylinder walls,
inhibiting break-in. You simply want to get it into the air following
the overhauler's break-in procedure to the letter.
On 9/18/2011 7:59 AM, Bob Collins wrote:
start-up of an RV's engine. In my case, it's an IO-360-B1B (from
mattituck). I ask because I noticed on Mr. Checkoway's site that
there was a 5-minute warm-up period (according to his people who were
assisting him) and then he ran it to run-up power, though I'm not sure
for how long, nor what tests -- if any -- he was doing during the
run-up, or during the 5 minute-warm-up.
to KSGS next Saturday and letting me tie an airplane to its bumper?
Do not archive.
KCHD |
dcw(at)mnwing.org Guest
Posted: Sun Sep 18, 2011 3:06 pm Post subject: Engine start-up regimen |
Agreed. Bart LaLonde at Aerosport recommends no longer than a 3-minute
ground run. I would look for oil pressure and general operation of all
engine instrumentation and a mag check (or EI check). That's it. The
next engine start should be the first flight.
Doug Weiler
On 9/18/2011 10:11 AM, Kelly McMullen wrote:
temperatures cold enough to require an engine pre-heat.
you have any leaks fixed and oil pressure where it belongs, any
further ground run just increases the chances of glazing cylinder
walls, inhibiting break-in. You simply want to get it into the air
following the overhauler's break-in procedure to the letter.
> sure for how long, nor what tests -- if any -- he was doing during
> the run-up, or during the 5 minute-warm-up.
> Do not archive.
david.nelson(at)pobox.com Guest
Posted: Mon Sep 19, 2011 4:38 am Post subject: Engine start-up regimen |
Hi Bob,
| Quote: | From Mattituck's (your engine manufacturer) TMX FAQ:
http://www.mattituck.com/tmxfaq.htm
In the section "Do I need extra test cell run time on my new TMX experimental
engine to prevent cylinder glazing during my ground testing phase?":
"If the CHT goes above 350*F or the oil temp goes above 180*F at any point
during the 10 minute max duration ground run, or at the expiration of the ten
minute time limit, that run should be terminated."
It's a very exciting time when you hit that starter and the engine fires for
the first time!
Good luck,
/\/elson
On Sun, 18 Sep 2011, Bob Collins wrote:
Wondering if there's a generally-accepted regimen for the first start-up of
an RV's engine. In my case, it's an IO-360-B1B (from mattituck). I ask
because I noticed on Mr. Checkoway's site that there was a 5-minute warm-up
period (according to his people who were assisting him) and then he ran it to
run-up power, though I'm not sure for how long, nor what tests -- if any --
he was doing during the run-up, or during the 5 minute-warm-up.
Also if anyone in St. Paul has a pick-up truck, how 'bout coming out to KSGS
Do not archive.
Bob Collins
Posted: Sat Sep 24, 2011 8:36 pm Post subject: Engine start-up regimen |
Just a quick update: We started the engine today and everything went
fine. Comedy and video here:
http://rvnewsletter.blogspot.com/2011/09/clear.html
On 9/18/2011 9:59 AM, Bob Collins wrote:
Do not archive.
St. Paul, Minn.
rv8iator(at)gmail.com Guest
Posted: Sun Sep 25, 2011 5:37 pm Post subject: Engine start-up regimen |
Bob...
Fantastic! Glad to see your project is moving forward.
Chris stone
Sent from my iPad
On Sep 24, 2011, at 9:33 PM, Bob Collins <bcollinsrv7a(at)comcast.net> wrote:
Just a quick update: We started the engine today and everything went fine. Comedy and video here:
> Wondering if there's a generally-accepted regimen for the first start-up of an RV's engine. In my case, it's an IO-360-B1B (from mattituck). I ask because I noticed on Mr. Checkoway's site that there was a 5-minute warm-up period (according to his people who were assisting him) and then he ran it to run-up power, though I'm not sure for how long, nor what tests -- if any -- he was doing during the run-up, or during the 5 minute-warm-up.
> Also if anyone in St. Paul has a pick-up truck, how 'bout coming out to KSGS next Saturday and letting me tie an airplane to its bumper?
> Do not archive.
