Posted: Fri Sep 09, 2011 5:19 am Post subject: AeroLed landing lights not working with wig wag relay |
At 07:56 AM 9/9/2011, you wrote:
I purchased the B&C wig wag relay and wired it according to the
schematic for an off-on-on switch and B&C diode assembly. The
wig-wag is in the middle position. I included the resistors between
the relay and ground shown in the updated schematic. The system
works fine with incandecent nav lights but not with the LED landing
lights. Only one LED light turns on in wig wag mode and both lights
turn on in continuous on mode. The nav lights draw about 3.2 amps,
the LED lights about 3.7 amp. Anyone know what is going on here and
how to fix it. Should I just purchase an electronic wig wag unit
designed for LED's?
I modified that drawing for B&C based on testing I
did using one of the flashers from their inventory.
The resistors were added to emulate the fixed load
offered by incandescent lamps. You are the second
individual who was unable to duplicate the behavior
I was getting on the bench. I have a pair of Whelen
LED landing lights loaned to me by another reader
and I plotted their current draw vs. voltage curve
which I posted on the List a few days ago.
I'm somewhat tied up with some family matters and
can't get back to the bench right now to figure out
what's going on . . . but the solution will not
be difficult. Sit tight for the moment . . . watch
this space.
Helidesigner
Posted: Sat Oct 01, 2011 5:34 am Post subject: Re: AeroLed landing lights not working with wig wag relay |
Hi Bob,
I received the updated wiring diagram from B&C that has the 2W 75 ohm resister across the light terminals. I gave it a try and had the same result. Any idea what is going on? Are the Aeroled lights different than the Whelens I saw in the picture?
_________________ Thanks |
