Posted: Fri Oct 07, 2011 11:29 am Post subject: What kind of max RPMs are you getting from your IO540 |
I'm still under 40 hours on my IO540-D4A5. On takeoff (from 350' MSL)
I'm getting a momentary max RPM of 2690 at that point in the ground run
when the engine speed up to it's max. Then it settles down to 2540 for
lift-off and initial climb. (figures from GRT logs)
I understand the max rated power is achieved at 2700 rpms. I'm thinking
that's consistent with what I'm seeing. Is it? Are seeing similar numbers?
Thanks.
Bill "flying a little and tinkering a lot" Watson
jcumins(at)jcis.net Guest
Posted: Fri Oct 07, 2011 12:00 pm Post subject: What kind of max RPMs are you getting from your IO540 |
Bill
Sounds like the governor max stop is a bit off. You should be able to get
2700 in flight at full power.
John Cumins
President
707-425-7100
707-425-7576 Fax
Jim Combs
Joined: 24 Jan 2010 Posts: 140 Location: Lexington, Ky
Posted: Fri Oct 07, 2011 12:01 pm Post subject: What kind of max RPMs are you getting from your IO540 |
Are you jumping on the throttle fast enough to have the engine overrun the governor. Especially if the oil is cool?
Sounds like it from your description and making the assumption (I know what that leads to!) that you have the prop full in for the initial takeoff and climb?
Jim Combs
On Fri, Oct 7, 2011 at 3:24 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
[quote] --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
I'm still under 40 hours on my IO540-D4A5. On takeoff (from 350' MSL) I'm getting a momentary max RPM of 2690 at that point in the ground run when the engine speed up to it's max. Then it settles down to 2540 for lift-off and initial climb. (figures from GRT logs)
I understand the max rated power is achieved at 2700 rpms. I'm thinking that's consistent with what I'm seeing. Is it? Are seeing similar numbers?
Thanks.
http://forums.matronics.com
le, List Admin.
_________________ RV-10 -> N312F - Flying as of 12/2008 |
Posted: Fri Oct 07, 2011 12:15 pm Post subject: What kind of max RPMs are you getting from your IO540 |
That's probably true. I do have it full forward for takeoff and intial climb.
Previous to this, my only CS prop time was about 10 hours in a Mooney so this is new territory.
Bill
On 10/7/2011 3:59 PM, Jim Combs wrote: [quote]Are you jumping on the throttle fast enough to have the engine overrun the governor. Especially if the oil is cool?
Jim Combs
Quote: | --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Thanks.
le, List Admin.
| [b]
Posted: Fri Oct 07, 2011 12:16 pm Post subject: What kind of max RPMs are you getting from your IO540 |
That may well be the case. Seems like it should be easy to remedy.
Will have to hit the manuals. Any advice welcome here.
Bill
On 10/7/2011 3:51 PM, John Cumins wrote:
Bill
John Cumins
President
707-425-7100
707-425-7576 Fax
n223rv(at)wolflakeairport Guest
Posted: Fri Oct 07, 2011 12:27 pm Post subject: What kind of max RPMs are you getting from your IO540 |
I get 2700 rpm on takeoff and through climb until I dial it back.... Sounds like your governor needs a small adjustment. Easy to do, but trial and error to set it right. It should be in the manual.
-Mike
Thanks.
Posted: Fri Oct 07, 2011 12:38 pm Post subject: What kind of max RPMs are you getting from your IO540 |
I think that's strange too. The faster the airplane goes the higher the
RPM .... to a point. Did you get the numbers backwards?
I looked in my manual. The HP depends on how much fuel you can feed it.
(CR = 8.5:1, 25 BTDC timing)
At best power the engine produces
75% power (at) 2700 RPM (at) 17+ GPH
85% power (at) 2700 RPM (at) 19- GPH
and the graph continues up to 260HP (at) 21.5 GPH!
All at 2700 RPM.
Now, upgrade to the IO-540-K (8.7:1 CR and 20 deg BTDC timing) and you get
75% power (at) 2700 RPM (at) 19 GPH
85% power (at) 2700 RPM (at) 21 GPH
and the graph continues up to 300HP (at) 24 GPH!
All at 2700 RPM.
I guess it all depends on the mission.
Quote: | I'm thinking that's consistent with what I'm seeing. Is it? Are
I wish I could answer that. I'm still building, and making some progress!!!
Linn
rv10rob(at)gmail.com Guest
Posted: Fri Oct 07, 2011 12:46 pm Post subject: What kind of max RPMs are you getting from your IO540 |
If you use the MT governor from Vans and the standard engine IO-540-D4A5 you will have the low RPM problem. See the governor manual, but I believe a complete turn of the high RPM stop screw yields a RPM increase of 50. Quick, simple adjustment.
With that set properly, you may see RPM above 2700 if you advance the throttle quickly for takeoff. That requires a propeller adjustment (see your prop manual).
-Rob
On Fri, Oct 7, 2011 at 1:13 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
That may well be the case. Seems like it should be easy to remedy. Will have to hit the manuals. Any advice welcome here.
Bill
[quote] --> RV10-List message posted by: "John Cumins"<jcumins(at)jcis.net (jcumins(at)jcis.net)>
Bill
John Cumins
President
[url=tel:707-425-7100]707-425-7100[/url]
[url=tel:707-425-7576]707-425-7576[/url] Fax
Posted: Fri Oct 07, 2011 1:12 pm Post subject: What kind of max RPMs are you getting from your IO540 |
I like to see a tiny bit over 2700, like 10 or 20 rpm. You should be able to get that right from the start. Power increases about proportionally with rpm so running 100 low loses you several horses.
Wish I could see MP at ambient...
--Dave
Thanks.
Kellym
Posted: Fri Oct 07, 2011 1:31 pm Post subject: What kind of max RPMs are you getting from your IO540 |
Those fuel flows sound low for full power. I would expect 22-23 gph,
because a 200 hp Lycoming needs ~17gph on takeoff to have EGT where you
want it, roughly 200 ROP, or about 1250F. 300 hp engine should need
around 26-27. I know an IO550 Continental with 310 hp needs 29-30 gph
for takeoff.
On 10/7/2011 1:34 PM, Linn Walters wrote:
Quote: | -I looked in my manual. The HP depends on how much fuel you can feed it.
All at 2700 RPM.
get
All at 2700 RPM.
progress!!!
Linn
> Thanks.
KCHD |
Bob Turner
Posted: Fri Oct 07, 2011 4:31 pm Post subject: Re: What kind of max RPMs are you getting from your IO540 |
My YIO-540-D4A5 data plate says it's certified for 260 HP at 2700 RPM, or 250 HP at 2600 RPM.
My guess is the effective (power to the airplane) power loss with lower RPM is smaller than that 10 HP, since the prop is less efficient at the higher RPM's.
I have the Hartzell governor, and it came pre-adjusted to 2650 RPM. I haven't bothered to tweak it upwards yet, and I'm wondering if I ever will. I like the idea of keeping the noise down a bit, and I certainly don't need the power from my home airport (400' MSL). Of course, if I'm at Leadville on a hot day and heavy, I may wish I had every HP available.
_________________ Bob Turner
RV-10 QB |
Bob Turner
Posted: Fri Oct 07, 2011 4:36 pm Post subject: Re: What kind of max RPMs are you getting from your IO540 |
PS to Bill:
You shouldn't be seeing a 150 RPM overrun of the governor, if you're taking at least a full second or more to push the throttle in. Either the oil hasn't warmed up, or the oil passage is clogged a bit, or something else. You do test the prop once or twice during run up, to get warm oil up there, right?
RV-10 QB |
Kelly McMullen
Posted: Fri Oct 07, 2011 6:18 pm Post subject: What kind of max RPMs are you getting from your IO540 |
Given the acceleration of the -10, on all but a sub-1000ft strip, I
would ease the throttle in slowly enough that you are at rotation
speed when you got full throttle(i.e. more than 5 sec). I don't like
to shock the plugs or cylinders with rapid throttle increases, and
learned years ago that very slow throttle addition prevented rock
dings in the prop when operating off gravel strips.
On Fri, Oct 7, 2011 at 6:20 PM, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
Quote: |
I do test, just once, and very briefly. It's the way I was taught. I'm
taking more than a second to push the throttle.
I'll be paying a lot more attention to these things the next couple of
takeoffs - we'll see.
On 10/7/2011 8:36 PM, Bob Turner wrote:
> PS to Bill:
> there, right?
> Bob Turner
> RV-10 QB
> http://forums.matronics.com/viewtopic.php?p=354354#354354
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Sat Oct 15, 2011 3:16 pm Post subject: What kind of max RPMs are you getting from your IO540 |
Coda; I pulled out the governor manual and a procedure for both static testing and in-flight testing were spelled out. I decided to leave the static alone and just do the inflight test. Made the adjustment required and overshot by 30 rpms or so. Readjusted and ready to go. Very simple and straight forward.
I tried a much slower application of power during takeoff and no longer have the "overspeed" situation.
Thanks all.
On 10/7/2011 4:43 PM, Rob Kochman wrote: [quote] If you use the MT governor from Vans and the standard engine IO-540-D4A5 you will have the low RPM problem. See the governor manual, but I believe a complete turn of the high RPM stop screw yields a RPM increase of 50. Quick, simple adjustment.
-Rob
Bill
