Is this the right stuff ?? cowling cushion seal
Doug Doty
PostPosted: Sun Oct 30, 2011 4:37 am    Post subject: Is this the right stuff ?? cowling cushion seal Reply with quote
http://www.aircraftspruce.com/catalog/cspages/cowlingchafeseal.php
The welting as I have always called it does not appear to have ever been installed on my plane, it surely was in the begining. I am talking about where the engine cowls folds down and lay against the aluminum tabs projecting forward from the firewall. I can see they have started to wear into the underside of the doubler on the cowl doors from chaffing together. I guess I am actually going from memory but was thinking there should be seal/cushion material on the under side of the cowl doors on the rear, help, what is correct.
1977 AA5B..........
1977 AA5B N28454, Fuel Totalizer, Lopresti Nose, Red Rudder Cap, 4 cyl. egt, stock otherwise.
