PMorel
Joined: 09 Jul 2007 Posts: 62 Location: Locust Grove, GA USA
Posted: Sat Nov 12, 2011 5:39 am Post subject: Classic IV Firewall |
I'm building a Classic IV and was hoping someone has the dimensions of the lower firewall panels. I'll be installing a Rotax 912 and I have the cutout for the starter for the panel. I only need the dimensions for the center and ether left or right panel since I assume they are the same size. Thanks
Paul
_________________ Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Nov 12, 2011 8:19 am Post subject: Classic IV Firewall |
Paul,
The dimensions of what I would call the foot wells are : top forward bend begins right below the side engine mount and is 4" to the downward bend. The lower section runs from that bend 10-3/8" to the bottom bend. This results is a foot well that extends forward of the plane of the firewall slightly under 4" at the top, tapering to zero at the bottom. The extension that fits over and around the bottom front of the fuselage is 1-3/8" top to bend and then extends aft under the fuselage 5-3/8". The gap between the foot wells is 6" wide.
If this sounds confusing, drop another note.
Lowell
Sent: Saturday, November 12, 2011 5:36 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: Classic IV Firewall
Paul
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
