Dillfamily(at)sbcglobal.n Guest
Posted: Sat May 27, 2006 4:39 am Post subject: 582 wiring |
I want to trace out the wiring on my used M2 with 582 before I fly it. I =
looked for a few minutes in the archives for a schematic. None was =
found, however some insight was provided in "Rotax Charging" dated =
4/18/20006. I gather that I will find a grey wire which goes to the =
tach. Then there is a yellow and a yellow/black wire which come from the =
stator. Not to be confused with the black/yellow shorting wires. Forgive =
me. At this point I am not even sure about the major components. What is =
the stator and what gadgets perform the duties of magneto and alternator =
on this engine?=20
Looking at the engine, I have one yellow, one brown, one grey, and three =
combination yellow/black (two of which are presumably shorting wires). =
Any further explanation would be appreciated.=20
I have what is probably a regulator mounted on my firewall, with two =
yellow input, black ground and a red output that disappears into my =
starter switch. Is it a rectifier too? Why two inputs? One of the yellow =
wires is connected to the yellow wire from the engine, the other is =
connected to one of the yellow/black combinations. (If the other two =
yellow/blacks are for magneto grounding, I guess that names all three). =
Am I homing in on the right answers? What is the brown wire for?=20
Does anybody have a link to a schematic?
Jeff Dill, M2
torgemor(at)online.no Guest
Posted: Sat May 27, 2006 7:51 am Post subject: 582 wiring |
Hi Jeff,
Here's a direct link to a 582 schematic at CPS's homesite:
http://www.800-airwolf.com/pdffiles/ARTICLES/part32.pdf
If you go to this one, you'll find lot's of tech. articles:
This is just another place where you'll be able to download a Rotax 582
installation manual, roll down to page 18-4 and you'll find the right
stuff:
http://www.rotax-aircraft-engines.com/pdf/dokus/d00287.pdf
For others, go here and you'll find most of the Rotax manuals:
http://www.lycon.se/rotax/Index-eng.htm
Good luck
Torgeir
Model II with 532 engine.
On Sat, 27 May 2006 08:37:57 -0400, Dill Family <Dillfamily(at)sbcglobal.net>
wrote:
on this engine?=20
Jeff Dill, M2
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
dave(at)cfisher.com Guest
Posted: Sun May 28, 2006 3:14 am Post subject: 582 wiring |
Hi jeff.
Brown == ground
Grey = Tach
you right on yellow and 3 yellow/ bl
- 2 for grounding
2 for regulator/rectifier.
And yes is a combination rectifier/ voltage regulator.
Schematics here http://www.ultralightnews.ca//ducati/index.html
Red off regulator is the + and should be keyed to the battery .
Dave
