bcondrey
Posted: Sat May 27, 2006 12:35 pm Post subject: ELT Rubber Ducky Antenna? |
Bob N.,
In the past you've cited the possibility using a rubber ducky style antenna for ELTs. Would this also be an option for the newer style 121.5/406 MHz types such as the Artex ME406?
nuckollsr(at)cox.net Guest
Posted: Sat May 27, 2006 2:44 pm Post subject: ELT Rubber Ducky Antenna? |
At 01:35 PM 5/27/2006 -0700, you wrote:
<bob.condrey(at)baesystems.com>
Bob N.,
Only if the "rubber duck" has been crafted for dual frequency
operations. The instance I suggested that the shortened antenna
be considered was the case where a pair of antennas . . . a 121.5
and a 406 MHz device were mounted side by side under the fiberglas
toe cover of the vertical fin fairing on a Beechjet:
http://www.aeroelectric.com/temp/400A_ELT.jpg
When the fairing cover was installed, metallic braces in
the fairing upset the SWR on the longer, 121.5 MHz antenna
and caused self-test failures. They considered the short antenna
until we discovered that the ELT had been qualified under TSO with
these specific antennas . . . we couldn't use a different
antenna without re-qualifying. So . . . they widened the
trip tolerance on the SWR self check . . . another case where
under very un-helpful regulation, two wrongs made a "right."
(sigh)
Anywho, I suspect your more modern design is paired with
an antenna designed for optimum performance at two frequencies
and the simple rubber duck is not an option for you.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
Posted: Sat May 27, 2006 3:05 pm Post subject: ELT Rubber Ducky Antenna? |
| Quote: | >
The Artex 121.5/406.028 MHz ELTs can be bought bundled with antennas
selected to support the dual frequencies. That's what I did. I'll tell you
how it works after my next crash.
-- Craig
