Posted: Thu Jan 05, 2012 11:26 am Post subject: Battery placement |
Hello everybody
I am helping a buddy who is beginning the construction of a -10.
Reading the Manual, I became aware that the plans determine the battery to be placed in the tail.
Has everybody gone this way, or did any of you placed the battery elsewhere?
Carlos Trigo
Bob Turner
Posted: Thu Jan 05, 2012 12:05 pm Post subject: Re: Battery placement |
If you are building a standard Van's plane (IO-540 engine) you will probably find that the c.g. comes out on the forward side of the limits. Many find they need to carry some ballast in the back when flying solo. So leaving the battery in the back seems like a good idea.
The only ones I have heard of who moved the battery forward were using alternative engines.
_________________ Bob Turner
RV-10 QB |
speckter(at)comcast.net Guest
Posted: Thu Jan 05, 2012 12:10 pm Post subject: Battery placement |
Most folks are putting it in the tail per the plans. It seems to be the best place to make the CG come out where it needs to be.
Gary Specketer
Sent: Thursday, January 5, 2012 2:18:50 PM
Subject: Battery placement
Hello everybody
Carlos Trigo
rv10flyer(at)verizon.net Guest
Posted: Thu Jan 05, 2012 12:20 pm Post subject: Battery placement |
In my case I am quite happy I DID leave it in that position. My W&B has me Fore of center and I need a good 50lbs in the tail while flying alone. Unless there is a good reason to move it elsewhere (not firewall forward is my suggestion) make sure you consider that Vans designed the plane around everything being where the plans state they should go so if you move the battery consider the W&B issue it can cause.
Pascal
Sent: Thursday, January 05, 2012 11:18 AM
Hello everybody
Carlos Trigo
Posted: Thu Jan 05, 2012 12:42 pm Post subject: Battery placement |
Go with the Van’s position – assuming you are using a standard IO-540 engine.
I put two Odyssey PC-625 batteries there by doing a simple mod to the supplied Van’s battery holder.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Thursday, January 05, 2012 2:19 PM
Hello everybody
Carlos Trigo | Quote: | | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com | 012345
dlm34077(at)q.com Guest
Posted: Thu Jan 05, 2012 2:23 pm Post subject: Battery placement |
I have 2 680s in the normal position and dual master switches on the panel; the intent was a backup battery in the rear. After loading my normal 40# tool box and another box of spare part and extra survival gear in the baggage compartment I decided on another 680 on the right side forward firewall which only powers the essential bus and is charged by the alternator. I can start from either main battery and provide about another 40A from the essential battery by pulling (manually) the breakers for the avionics/EFIS.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs
Sent: Thursday, January 05, 2012 1:06 PM
Subject: Re: Battery placement
The plans location have been followed by everyone. Changes include:
(1) Installing a second backup battery Still in the tailcone.
(2) Modifying the holder to install a larger (680) battery.
There are no weight issues with installing a larger battery or a second battery in the same location.
JIm Combs
N312F (Flying) - 320 hours
On Thu, Jan 5, 2012 at 2:18 PM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Hello everybody
Carlos Trigo
| Quote: | | get="_blank">http://www.matronics.com/Navigator?RV10-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution |
0123456789 | Quote: | | get="_blank">http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | get="_blank">http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | get="_blank">http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | get="_blank">http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | get="_blank">http://www.matronics.com/Navigator?RV10-List | 4 | Quote: | | get="_blank">http://www.matronics.com/Navigator?RV10-List | 5
rv10flyer
Posted: Thu Jan 05, 2012 5:16 pm Post subject: Re: Battery placement |
925/680 in back. Ewcg 1/2" aft of fwd limit. Extra 100 lbs in baggage makes for easier landings, lighter in pitch, and 4 kts higher cruise when solo.
_________________ Wayne G. |
