w_wester(at)bellsouth.net Guest
Posted: Thu Jan 12, 2006 10:27 am Post subject: fuel servo clearance ??? |
Hi. I am planning to build a F1 Rocket in the future.
I have already acquired a 3 blade Hartzell and an engine.
I have not ordered the airframe kit due to time and money constraints, and due
to anticipation of further improvements to the kit.
Now for the question. My engine is a TIO540-AG1A.
Basically, it has 270 HP, dual mags, parallel valve, and long reach heads.
The engine also has the large hole mounting ears.
I have already gotten rid of the turbo and all turbo related accessories.
The fuel servo mounts on the rear/center/bottom of the oil sump.
Is this going to cause a clearance problem with the engine/gear mount?
Are there any other issues with this engine that I should be aware of?
Thanks, Wayne
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Rocket-List |
Posted: Thu Jan 12, 2006 11:55 am Post subject: fuel servo clearance ??? |
<< The fuel servo mounts on the rear/center/bottom of the oil sump.
I should have been more clear on the mounting of the fuel servo.
The fuel servo mounts on the rear/center of the oil sump.
The inlet for the fuel servo faces the rear of the plane and not
the bottom of the engine.
Wayne
fairlea(at)amtelecom.net Guest
Posted: Thu Jan 12, 2006 1:57 pm Post subject: fuel servo clearance ??? |
I would recommend that you at least change the sump on the engine to the
C4B5 type sump. I am not sure what long reach heads are, but if they stick
out any further than the standard heads, the cowlings will probably not fit
properly. You might want to check for correct counter weights, fuel pump
and also the crankshaft flange to see if these are compatible. Also find out
how much this engine weighs compared to a C4B5 block. You do not want any
more weight out in the front of this plane.
Tom Martin
