tomcostanza
Posted: Mon Jan 30, 2012 6:49 pm Post subject: Transponder antenna |
Should I be concerned about mounting a transponder antenna near fuel lines/fittings?
_________________ Clear Skies,
Tom Costanza
-- in year 17 of a 3 year project |
fvalarm(at)rapidnet.net Guest
Posted: Mon Jan 30, 2012 7:40 pm Post subject: Transponder antenna |
Good question.
Don't have an answer but would also like to know if the transponder needs
some backing reinforcement or just mount it to the belly skin?
Bevan
stein(at)steinair.com Guest
Posted: Mon Jan 30, 2012 8:38 pm Post subject: Transponder antenna |
No worry about where you mount it, but re-enforcement is dependent on which antenna you use, where it is at, skin thickness, etc...
Stein
On Jan 30, 2012, at 9:37 PM, "B Tomm" <fvalarm(at)rapidnet.net> wrote:
Good question.
Bevan
Posted: Mon Jan 30, 2012 9:26 pm Post subject: Transponder antenna |
TED transponder on bottom belly skin of RV7. Probably 032 thick, maybe 040.
Bevan
Float Flyr
Posted: Tue Jan 31, 2012 2:38 pm Post subject: Transponder antenna |
Assuming you have a metal plane mount it to the skin on the bottom of the
fuselage. Remember as with all antennae cleanliness counts! Lock washers do
help make a good connection to the skin but it is always better to have the
area directly under the antenna, on both sides shiny clean before
installing.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
