Clive J
Posted: Sun Feb 05, 2012 5:46 am Post subject: Draught from aileron tube holes |
Does anyone have a neat solution to the draught from the holes?
Ta, Clive
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
n45bm(at)yahoo.com Guest
Posted: Sun Feb 05, 2012 9:09 am Post subject: Draught from aileron tube holes |
The October, 2003 issue of Sport Aviation has an article (p.97) titled "Baby Gets New Booties". It shows how to make cone-shaped air draft covers from sail cloth that cover the hole in the fuselage and wrap around the stick. They still allow full aileron push rod deflection. These are on an RV-6, I believe, but can be used on the Lightnings easily. A paint strainer cone was cut, opened and used for a template. Check it out.
Bernardo
--- On Sun, 2/5/12, James, Clive R <clive.james(at)uk.bp.com> wrote:
Quote: |
Subject: Draught from aileron tube holes
To: lightning-list(at)matronics.com
Date: Sunday, February 5, 2012, 7:43 AM
Ta, Clive
| [quote][b]
IFLYSMODEL(at)AOL.COM Guest
Posted: Sun Feb 05, 2012 9:10 am Post subject: Draught from aileron tube holes |
Hey Clive: I had a problem with cold air coming up along the outside of the seat pan. I was in the process of making air dams for the flap controls when I thought of increasing the air flow OUT of the cabin. I put a vent in the rear bulkhead of the baggage compartment, and the cold air problem went away. So I never finished the air dams.
Lynn
In a message dated 2/5/2012 8:46:27 A.M. Eastern Standard Time, clive.james(at)uk.bp.com writes:
Ta, Clive
Clive J
Posted: Sun Feb 05, 2012 11:34 pm Post subject: Draught from aileron tube holes |
http://www.eaa732.org/sites/default/files/newsletters/2005-03.pdf
Found it here, many thanks, Regards, Clive
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Bernard Melendez, Jr.
Sent: 05 February 2012 17:05
Subject: Re: Draught from aileron tube holes
Bernardo
--- On Sun, 2/5/12, James, Clive R <clive.james(at)uk.bp.com (clive.james(at)uk.bp.com)> wrote:
From: James, Clive R <clive.james(at)uk.bp.com (clive.james(at)uk.bp.com)>
To: lightning-list(at)matronics.com (lightning-list(at)matronics.com)
Ta, Clive
Quote: | http://www.matronics.com/Navigator?Lightning-List | 0123456789
Clive J
Posted: Mon Feb 06, 2012 12:30 am Post subject: Draught from aileron tube holes |
Thanks Lynn, I have a few holes under the seats going backwards already, the air seems to come up around my knees suggesting there is a way out perhaps a good one!
Regards, Clive
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of IFLYSMODEL(at)AOL.COM
Lynn
In a message dated 2/5/2012 8:46:27 A.M. Eastern Standard Time, clive.james(at)uk.bp.com (clive.james(at)uk.bp.com) writes:
Ta, Clive | 01234567890123
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
