ventilation
fredorosa(at)gmail.com
PostPosted: Sun Feb 26, 2012 12:55 pm    Post subject: ventilation Reply with quote
I have a question to you people flying about cabin ventilation.  I have 2 eyeball vents on the panel for air intake
but haven't provided any vent for exhausting cabin air.  In an exhaust vent necessary or does the opening where
the elevator passes through the rear fuselage act as an exhaust vent?
Al
ftyoder(at)yoderbuilt.com
PostPosted: Sun Feb 26, 2012 2:30 pm    Post subject: ventilation Reply with quote
Al,
I think there are many unsealed holes in our planes, unless you build a pressurized cabin. In my TR-1 I stop the cold air from coming in past the flap handle by opening the cabin heat valve. Even with the vents closed the cold air enters , low pressure area. I doubt you would need to add any additional exhaust vents.
Regards, Tim N52TY
galinhdz(at)gmail.com
PostPosted: Sun Feb 26, 2012 2:37 pm    Post subject: ventilation Reply with quote
Mine has no exhaust vent so I guess the opening works just fine.
I have been debating about making a good seal on the rear bulkhead panel so I can use that area as a good place to put an outside air temperature sensor, but now that you bring this up I may just leave it as it is.
Galin
On Sun, Feb 26, 2012 at 2:54 PM, ALFRED ROSA <fredorosa(at)gmail.com (fredorosa(at)gmail.com)> wrote:
[quote] I have a question to you people flying about cabin ventilation.  I have 2 eyeball vents on the panel for air intake
Al
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
wschertz(at)comcast.net
PostPosted: Sun Feb 26, 2012 2:48 pm    Post subject: ventilation Reply with quote
There are enough leaks that you don’t need anything specific
Bill Schertz
KIS Cruiser #4045
N343BS
Phase one testing Completed
Sent: Sunday, February 26, 2012 2:54 PM
To: kisbuilders (kis-list(at)matronics.com)
Subject: ventilation
Al
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
sstearns2(at)yahoo.com
PostPosted: Mon Feb 27, 2012 4:21 am    Post subject: ventilation Reply with quote
I put my OAT sensor in the aft portion of the wing root fairing. Seems to work fine.
Scott
On Feb 26, 2012, at 2:36 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote]Mine has no exhaust vent so I guess the opening works just fine.
Galin
On Sun, Feb 26, 2012 at 2:54 PM, ALFRED ROSA <[url=mailto:fredorosa(at)gmail.com]fredorosa(at)gmail.com (fredorosa(at)gmail.com)[/url]> wrote:
Al
bakerocb
PostPosted: Mon Feb 27, 2012 5:29 am    Post subject: ventilation Reply with quote
2/27/2012
Hello Al, My experience is that there is a significant flow of air (cold in the winter) that arrives from the rear of the airplane into the cockpit area when the eyeball vents are closed off.
Probably comes in around the opening in the fuselage tail where the elevator spar goes through. I have not yet come up with a practical means of blocking off this forward flowing cold air.
No problem with air flow coming into the cockpit through the eyeball vents when they are open during the summer.
'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge.
Sent: Sunday, February 26, 2012 3:54 PM
Al
