wb2ssj(at)rochester.rr.co Guest
Posted: Tue Mar 13, 2012 3:14 am Post subject: JabiruEngine-List: Re: worn valve guides |
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
Posted: Tue Mar 13, 2012 3:31 am Post subject: JabiruEngine-List: Re: worn valve guides |
Nick, thanks for the info. Have come to the same conclusion that the guides
were oversize for all the cylinders wore the same. Again thanks for the
info. Tex
info(at)jabiru.cl Guest
Posted: Thu Mar 15, 2012 7:19 am Post subject: JabiruEngine-List: Re: worn valve guides |
Hi Group,
We found the same problem here in a 6 cylinder engine with about 80 hours of
use, last year. We send the engine back to Australia for inspection, and the
guides were changed to the correct size.
Christian Tannen
Jabiru Chile
-----Mensaje original-----
De: owner-lightning-list-server(at)matronics.com
[mailto:owner-lightning-list-server(at)matronics.com] En nombre de Tex Mantell
Enviado el: martes, 13 de marzo de 2012 8:31
Para: jabiruengine-list(at)matronics.com; lightning-list(at)matronics.com
Asunto: Re: JabiruEngine-List: Re: worn valve guides
<wb2ssj(at)rochester.rr.com>
info. Tex
Posted: Thu Mar 15, 2012 10:34 am Post subject: JabiruEngine-List: Re: worn valve guides |
Thank You for the reply TEX
Posted: Fri Mar 16, 2012 2:27 am Post subject: JabiruEngine-List: Re: worn valve guides |
Clive,
I have another 2200 with the problem and its #2523. I plan to find the guides local if Possible for I have the tools to do it. I hope to contact someone to find out what spec material should be used if I have to make them. The bronze material comes in many flavors. Also I will have to determine the proper size for each valve when I get the heads off. If I remember right you found that the VW golf had a similar size guide. How did that work out? Will keep you posted and again thanks for your reply.
Tex
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
