mark.t.mueller(at)comcast Guest
Posted: Sun Mar 18, 2012 4:31 am Post subject: High CHT on #2 mystery |
Just picked 33R up from annual inspection yesterday, and when flying back to my home 'drome I could not keep my #2 CHT under 400 regardless of power setting, airspeed, or altitude. At 3500' and 2600 RPM in level cruise with an OAT of 72F #2 hit 440!!! This was NOT the case before annual except in extended climb. That cylinder is now running a good 30 - 40 hotter than before annual. The rest of the cylinders are running close to where they were before annual.
Oil temp stayed below 190.
I asked my IA what had been done, and he said the only thing he had to do was adjust the timing on one mag by a couple degrees and replaced the gasket on that mag. I have a LASAR ignition, and he allegedly used the T-300 tool I provided.
The SB388C test was done, and he stated was well within tolerance, and good comps on all cylinders.
Prior to annual, the #2 had a much higher EGT than the others, but normal CHT. All four CHTs were within 20+- during normal cruise. Now they are a good 40+ difference between #2 and coolest. Front cyls have always run hotter than rear since my baffling was rebuilt during OH 4 years ago.
Now, the obvious answer is my timing is screwed up, but the motor is running more smoothly and stronger than ever (smoother than before annual) and I don't want to give that up. In addition, in my experience owning 33R it is almost NEVER the "obvious" answer...
I still have to take a day off work and root around to see if there was any damage to the front baffling when they reassembled the cowling or other simple things (I am really hoping it's something simple).
Looking for ideas. It is clearly a thermodynamics problem, but what might be the best way to approach this without sacrificing the best my motor has run in a while?
Is it possible that low batteries in the T-300 tool might have caused an error in adjusting timing?
What are common baffling issues that might contribute to such a dramatic change in #2 CHT without significantly effecting the other cylinders?
Is it possible one cylinder is hypersensitive to timing over all the others? If so, what might this indicate that doesn't show up on an SB388C or other routine engine examination during annual?
Thanks in advance,
Mark T. Mueller
Tiger N1533R
| - The Matronics TeamGrumman-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
flyv35b(at)minetfiber.com Guest
Posted: Sun Mar 18, 2012 5:19 am Post subject: High CHT on #2 mystery |
On 3/18/2012 5:30 AM, Mark T. Mueller wrote:
Quote: | Just picked 33R up from annual inspection yesterday, and when flying
years ago.
Thanks in advance,
Mark T. Mueller
Tiger N1533R
Is your plane an AG-5B? What kind/brand of CHT/EGT instrumentation?
Cliff
Posted: Sun Mar 18, 2012 10:08 am Post subject: High CHT on #2 mystery |
I would double check the timing. If it seems smoother, it's likely the timing was bumped up enough to make a difference. It's all a compromise. EGT vs CHT.
From: Mark T. Mueller <mark.t.mueller(at)comcast.net>
Sent: Sunday, March 18, 2012 5:30 AM
Subject: High CHT on #2 mystery
Thanks in advance,
Mark T. Mueller
Tiger N1533R
Quote: | http://www.matronics.com/Navigator?TeamGrumman-List==================
my guess, Cheetah with JPI
Sent: Sunday, March 18, 2012 6:19 AM
Subject: Re: High CHT on #2 mystery
--> TeamGrumman-List message posted by: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
years ago.
Thanks in advance,
Mark T. Mueller
Tiger N1533R
Is your plane an AG-5B? Whatp://www.matronics.com/Navigator?TeamGrumman-List" target="_blank">http://  ========================
Posted: Mon Mar 19, 2012 1:41 am Post subject: High CHT on #2 mystery |
Quote: | Is your plane an AG-5B? What kind/brand of CHT/EGT instrumentation? Cliff
1975 AA-5B, VM-1000 Engine Instrument | Mark T. Mueller
Tiger N1533R
