mrspudandcompany(at)veriz Guest
Posted: Fri Mar 23, 2012 9:57 am Post subject: Expanded horizons (automotive question) |
Let me be the first with the "Expanded Horizons" to ask an automotive
question regarding fault code readers.
I have a 1996 GMC Sonoma, Similar to the Chevrolet S-10. My brake line
rusted through and dumped the brake fluid, resulting in air entering the ABS
unit. After bleeding the ABS module I still have the ABS light illuminated.
Brakes seem to work fine but no ABS. I purchased an inexpensive code
reader, but it seems that this works on almost all GM vehicles starting at
1996, but would you believe, not mine! Anyone have experience with this
problem, including how to fix it, and where I might, if needed, get a code
reader? Any help appreciated.
Posted: Fri Mar 23, 2012 11:07 am Post subject: Expanded horizons (automotive question) |
At 12:55 PM 3/23/2012, you wrote:
<mrspudandcompany(at)verizon.net>
A 'tad' bit outside the herding of electrons
but I think you can find legacy code readers
on eBay. It seems likely that with contaminated
electronics, the device is probably toast
and needs replacement. If push comes to shove,
you can pay the tariff for a local read of
the codes . . . but it will probably confirm
what seems most likely.
