dlm34077(at)q.com Guest
Posted: Fri Mar 30, 2012 12:03 pm Post subject: length of exhaust pipes |
Any correlation between the length of exhaust tubes and the length and breadth of the exhaust soot on the belly? How long are your exhaust tubes? How much crud on the underside?
rv10flyer(at)verizon.net Guest
Posted: Fri Mar 30, 2012 12:37 pm Post subject: length of exhaust pipes |
I think most of the crud comes from the oil blow-by. I don’t really have any soot on my belly, I have a oil separator that I drain every once in while.
Sent: Friday, March 30, 2012 1:01 PM
Subject: length of exhaust pipes
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Fri Mar 30, 2012 2:04 pm Post subject: length of exhaust pipes |
I bet you haven't even been under your plane to even think about cleaning the belly! Boy was the flight down to the keys and the lunch in Marathin GREAT today.
Sent: Friday, March 30, 2012 3:36 PM
Subject: Re: length of exhaust pipes
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
_________________ Don A. McDonald
40636 |
rv10flyer
Posted: Fri Mar 30, 2012 3:12 pm Post subject: Re: length of exhaust pipes |
Mine are really long. I run lean except for takeoff/climbout. During break in a ran rich and exhaust pipes were black inside. Now tan. After 10 hrs I get a really thin layer of oil on the bottom.
_________________ Wayne G. |
mauledriver(at)nc.rr.com Guest
Posted: Sat Mar 31, 2012 4:18 am Post subject: length of exhaust pipes |
With the 'factory' engine setup and exhaust, I don't really get any soot at 125hrs+. I'll try to remember to measure the clearance next time I get to the plane
I do get oil which seems to all come from the breather tube. I should have a better measure but it seems to be down about a quart per 25 - 30 hours. It stays pretty clean.
I do get a little soot coming out of the gear exit points at the wing roots (??)
Bill
On Mar 30, 2012, at 4:01 PM, "DLM" <dlm34077(at)q.com (dlm34077(at)q.com)> wrote:
Tim Olson
Posted: Sat Mar 31, 2012 11:39 am Post subject: length of exhaust pipes |
That's not soot. That's rubber from the tires.
Tim
On 3/31/2012 7:16 AM, Bill Watson wrote:
| Quote: | With the 'factory' engine setup and exhaust, I don't really get any soot
get to the plane
roots (??)
Bill
mdaniell
Posted: Sat Mar 31, 2012 5:05 pm Post subject: Re: length of exhaust pipes |
.......or brake pad powder.
| Tim Olson wrote: | That's not soot. That's rubber from the tires.
Tim
get to the plane
roots (??)
Bill
kdbelue(at)charter.net Guest
Posted: Sun Apr 01, 2012 9:31 am Post subject: length of exhaust pipes |
And brake dust.....
On Mar 31, 2012, at 2:36 PM, Tim Olson <Tim(at)MyRV10.com> wrote:
Tim
> get to the plane
> roots (??)
> Bill
> Sent from my iPad
Tim Olson
Posted: Sun Apr 01, 2012 10:25 am Post subject: length of exhaust pipes |
Yes, that too. Some of it is definitely rubber if you scrape it
off you can tell. The particles are pretty good sized.
Tim Olson - RV-10 N104CD
On 4/1/2012 12:21 PM, Kevin Belue wrote:
And brake dust.....
> Tim
>> get to the plane
>> roots (??)
>> Bill
>> Sent from my iPad
>> On Mar 30, 2012, at 4:01 PM, "DLM"<dlm34077(at)q.com
Posted: Sun Apr 01, 2012 3:42 pm Post subject: length of exhaust pipes |
Well, brake dust and rubber particles do seem to shoot up the gear legs
and blow into and out of the fuselage near the gear exit holes. Didn't
expect that but now it all makes sense. I probably have more brake dust
and dirt than rubber... probably because more than 50% of my ops are on
a grass strip.
I took another look and measured my 'factory' engine and exhaust setup.
One pipe's opening starts 5" below the fuselage bottom, the other 6".
No noticeable soot on the fuselage bottom. The belly mounted antenna is
a bit darkened but it's way under the belly where no one can see it (or
clean) easily.
But as I said before, there is a good coating of oil. I cleaned it
recently but it oils up pretty quickly. Seems to come exclusively from
the breather. Can't correlate it to any excess oil consumption. A
little goes a long way.
Bill
On 4/1/2012 2:25 PM, Tim Olson wrote:
> And brake dust.....
> Sent from my iPhone
>> Tim
>>> soot
>>> get to the plane
>>> - 30
>>> roots (??)
>>> Bill
>>> Sent from my iPad
>>>> and
