Greg McFarlane
Joined: 12 Apr 2012 Posts: 58 Location: Albany Western Australia
charliewaffles
rv10flyer(at)verizon.net Guest
Posted: Sat Apr 14, 2012 8:07 am Post subject: Brake Spacers |
They are solid and agree with Charlie, better to go this route than try
anything else.
I was fortunate to get the Don McDonald spacers. He made a certain amount
and are now carried by Plane Innovations
http://www.planeinnovations.com/axlesbrackets.html, if you scroll down the
webpage there are a couple of other items, again Don specials that I also
have and they have been great for the seatbelts, passenger side never
dropped out in the air when not in use.
As a side note, I have the steel heater bypass
http://www.planeinnovations.com/heaterbypass.html. From experience, they
block all the heat and I don’t have a tunnel heat issue, not sure they are
related but I know from testing that the aluminum ones from the kit leak and
these don’t. There is a deflector that covers the door when closed which
helps block the forced air.
Pascal
Lew Gallagher
Posted: Sat Apr 14, 2012 8:21 am Post subject: Brake Spacers |
Hey Guys,
I think you may have missed Greg's point -- he has replaced the axel
extension as you have, and is using the old extension for brake spacers.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
