n223rv(at)wolflakeairport Guest
Posted: Sat Apr 21, 2012 4:18 am Post subject: Flap Question |
I noticed my flap leading edge hits my wing top skin in the fully up position just barely. I know the design of the other RV's necessitate a protective tape as they are always in contact with the upper skin in any position.
Just curious what other RV-10ers are doing, bending the top skin trailing edge slightly, or adding a protective tape?
-Mike
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sat Apr 21, 2012 4:28 am Post subject: Flap Question |
I put the protective tape on the underside of the top skin instead of the top of the flap. This way it still doesn't get scratched and the uv doesn't yellow it.
On Apr 21, 2012, at 5:15, Michael Kraus <n223rv(at)wolflakeairport.net> wrote:
-Mike
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
arplnplt(at)gmail.com Guest
Posted: Sat Apr 21, 2012 5:13 am Post subject: Flap Question |
I have tape on the underside of the top skin to prevent scratches. I also bent the top skin up just slightly.
Dave Leikam
-Mike
jump2(at)sbcglobal.net Guest
Posted: Sat Apr 21, 2012 5:20 am Post subject: Flap Question |
ditto bottom of skin
Patrick Thyssen
N15PT
Sent from my iPad
> Thanks
> -Mike
> Sent from my iPhone
Posted: Sat Apr 21, 2012 5:50 am Post subject: Flap Question |
I did the top of the flap. My thought was that anything getting stuck
between the tape and the skin will scratch the underside of the wing skin,
not the top of the flap.
Carl
toaster73(at)embarqmail.c Guest
Posted: Sat Apr 21, 2012 4:40 pm Post subject: Flap Question |
And what specifically are the type of tapes that are being used??
Thank
Chris
N919AR
drfred(at)suddenlinkmail. Guest
Posted: Mon Apr 23, 2012 5:33 am Post subject: Flap Question |
Friend of mine is using the loop side of velcro on the underside of the wing for his RV8 .  Less expensive than the tape.
Dr Fred
515FW.
On 4/21/2012 7:39 PM, Chris wrote: [quote] body {height: 100%; color:#000000; font-size:12pt; font-family:Times New Roman;}And what specifically are the type of tapes that are being used??
Thank
Chris
N919AR
johngoodman
Posted: Mon Apr 23, 2012 7:50 am Post subject: Flap Question |
Have you priced Velcro??? 1"x10' is $16.99 online... UHMW 3"x10' is $12.00 thru Vans..... Plus I worry about stuff getting stuck in the Velcro like metal shavings and scratching the flap...
On Apr 23, 2012, at 9:31 AM, "Fred Williams, M.D." <drfred(at)suddenlinkmail.com (drfred(at)suddenlinkmail.com)> wrote:
[quote] Friend of mine is using the loop side of velcro on the underside of the wing for his RV8 . Less expensive than the tape.
Dr Fred
515FW.
Thank
Chris
N919AR
robin(at)PaintTheWeb.com Guest
Posted: Mon Apr 23, 2012 8:15 am Post subject: Flap Question |
Check eBay if you want to try the Velcro route. $3.39/wing delivered.
http://www.ebay.com/itm/2-5m-20mm-Black-Sticky-Self-Adhesive-Velcro-Hook-Loop-Tape-Strip-2-Rolls-N-/270918303729?pt=LH_DefaultDomain_0&hash=item3f13fd3ff1#ht_2755wt_979
Robin
Sent from the new iPad
On Apr 23, 2012, at 12:06 PM, "Michael Kraus" <n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)> wrote:
[quote] Have you priced Velcro??? 1"x10' is $16.99 online... UHMW 3"x10' is $12.00 thru Vans..... Plus I worry about stuff getting stuck in the Velcro like metal shavings and scratching the flap...
Dr Fred
515FW.
Thank
Chris
N919AR
Jim(at)JimVillani.com Guest
Posted: Mon Apr 23, 2012 8:30 am Post subject: Flap Question |
Grainger has it on Closeout for 11.54 3” 36 yards
http://www.grainger.com/Grainger/Single-Coated-Film-Tape-3ZWN5?Pid=search
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Monday, April 23, 2012 9:14 AM
Subject: Re: Flap Question
Robin
Dr Fred
515FW.
Thank
Chris
N919AR
Posted: Mon Apr 23, 2012 3:35 pm Post subject: Flap Question |
Ahhh! I have an old partial roll of that stuff, so I guess that's what I
will try.
-Chris
