saolesen(at)sirentel.net Guest
Posted: Tue May 15, 2012 7:13 am Post subject: iPad 3 flying observations |
I've had my iPad 3 out flying a few times and I have made a few observations. I like to keep the iPad battery charged up while flying so I use the cigarette lighter receptacle to hold a 12v charger. The 1 amp charger I used for the iPad 1 will not charge the new model. So I bought a new charger from Radio Shack that will put out 2.1 amps. The iPad indicates that it is being charged but the battery level keeps going down although more slowly. I wanted something that would at least keep the level even or increase the charge. On the return trip, I tried an inverter with the iPad wall charger plugged into it and that worked. The downside is that this is a very clunky way to get the desired result. I was using WingX and I had the cellular turned on so I could update the weather if the reception was good enough. No other devices were connected to the iPad. The screen brightness was set to about 1/2. Turning off the cellular off may help the battery situation.
I am not fond of the glossy screen when flying, so I bought a Brando nonglare screen protector to cure the problem. Unfortunately, the nonglare protector ruins the look of the Retina display and makes it look like the old iPad screen. The roughness of the matt screen gives the illusion of seeing individual pixels. I don't have a solution for this, and since one of the reasons I upgraded was the Retina screen, the nonglare protector may have to come off.
I had WingX quit a few times when I switched from the Moving Map display to Route Planning. I don't know why and I have sent an email to Hilton about the problem. Too early to have heard back from them.
Sheldon Olesen
RV-10 N475PV 385 hrs
dlm34077(at)q.com Guest
Posted: Tue May 15, 2012 8:11 am Post subject: iPad 3 flying observations |
Check amazon; they have one designed to charge the IPAD.
