dick(at)minetfiber.com Guest
Posted: Sun May 13, 2012 8:40 am Post subject: SSF-1 WIG WAG Flasher |
I built my RV using a B&C SSF-1 wig wag. Wired it per Aeroelectric recommendations and it worked fine.
I changed one light to a Xenon lamp using a Philips Xen Drive XLD912 Standard power supply. This does not load the SSF-1 flasher as required so my wig wag no longer works. I would like to keep the Xenon on one side and the incandescent lamp on the other. I would be happy with flashing one lamp if not both.
Any solutions?
Dick Wildman
jdubner(at)yahoo.com Guest
Posted: Sun May 13, 2012 11:18 am Post subject: SSF-1 WIG WAG Flasher |
Dick,
If you truly would be satisfied with flashing one lamp and if you have enough
power budget for the additional current the Xenon lamp requires and if you don't
mind a little re-wiring, you could substitute a power resistor for the
incandescent lamp that was removed. The resistor will keep the flasher happy.
Think of it as a non-illuminating lamp
Assuming you're using a 55W lamp at 14V, you would need 3.6 ohms capable of
dissipating 55 watts half of the time (50% duty cycle). A couple of 10-ohm,
20-watt resistors in parallel should be close enough to fool the flasher and if
not, add a third one. FYI, those resistors will get very hot; don't put then in
your lighting switch panel.
My wig-wag uses an electro-mechanical flasher too and this is what I plan to do
when I upgrade my lights unless I spring for a new (solid-state) flasher. But
that's not going to happen until after the airplane's flying <g>.
Joe
Independence, OR
http://www.mail2600.com/cgi-bin/webcam.cgi
Dick Wildman wrote:
Quote: | I built my RV using a B&C SSF-1 wig wag. Wired it per Aeroelectric recommendations and it worked fine.
Any solutions?
Dick Wildman
Posted: Sun May 13, 2012 5:17 pm Post subject: SSF-1 WIG WAG Flasher |
At 02:17 PM 5/13/2012, you wrote:
Dick,
have enough power budget for the additional current the Xenon lamp
requires and if you don't mind a little re-wiring, you could
substitute a power resistor for the incandescent lamp that was
removed. The resistor will keep the flasher happy. Think of it as a
capable of dissipating 55 watts half of the time (50% duty cycle). A
couple of 10-ohm, 20-watt resistors in parallel should be close
enough to fool the flasher and if not, add a third one. FYI, those
resistors will get very hot; don't put then in your lighting switch panel.
plan to do when I upgrade my lights unless I spring for a new
(solid-state) flasher. But that's not going to happen until after
If your new HID lamp/pwr-supply combo will tolerate
flashing, then you can also consider adding some dummy-load
resistance in parallel with the wires to the HID
power supply.
We did a patch to the B&C Wig-Wag instructions to
accommodate LED lamps, same fix should work with your
HID too.
http://tinyurl.com/7d5u7ny
There's a solid state wig-wag controller development
program under way right now
http://tinyurl.com/77ungjg
. . . parts I had on order to finish the proof of concept
boards spiraled down the USPS black hole when an error
in zip code left my parts looking for a Medicine Lodge
address . . . in spite of the fact that the printed address
was correct. Lessons learned, USPS mailed with a confirmation
track is delivered by USPS bar code . . . Address mail to
me at 67104-0130 as the ONLY address and it will get here.
Have an error in the zip code then it doesn't matter what
the rest of the address says . . . anywho, that all got
sorted out and the parts should be here Tuesday.
In the mean time, you could put 75 ohms across the HID
lamp supply . . . I think the B&C electronic flasher
will get happy again.
