mountain4don
Posted: Wed May 31, 2006 7:22 am Post subject: Design for Alcohol Engine |
It seems that the drift is toward more alcohol based fuels in auto engines here in Iowa. And more states are requiring alcohol in auto fuels to the point where it is difficult to find any straight gasoline anywhere anymore. So the question comes up, should I be designing an engine system for my 601 XL that will take advantage of alcohol based fuels when I am installing the engine in a year or two? Have there been any airplane engines set up for alcohol and flown with it successfully? Any of the auto conversions? I wonder about the altitude restrictions it would have due to its vapor pressure and the lower energy content requiring a higher fuel burn.
Don Mountain
| - The Matronics Zenith-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Zenith 601XL, tail done, working on wings |
frank.hinde(at)hp.com Guest
Posted: Wed May 31, 2006 8:06 am Post subject: Design for Alcohol Engine |
Now there is a hornets nest if ever there was one...
I have run my stratus soob on 10% ethanol fuel for 400 hours witout any
issue. Do search on the archives for a vapor lock free way to design a
fuel system, no matter what the fuel is...That is pumps in the wing
roots. And make sure you have high pressure air on the tank vents.
Data from a Hodges fuel vapour tester has shown E10 blended fuels to be
good to between 15 and 22,000 feet.
Note that these figures are at the temperature on the ground...Assuming
temp falls with altitude this gives a safety margin.
Note you can easily test each batch of fuel to give you the boil off
altitude. The issue is with the vapour boiling in the tanks, not vapour
locking the pumps ....As long as the pumps are not sucking on the fuel
of course.
The other argument against Ethanol blended fuels is they absorb
water...Should be a good thing except the solubility reduces with
altitude (or is that temperature?), so while you may have no water in
the sumps on the ground you could "make" water as you go higher. Is this
a real life issue? Personally I doubt it.
As to the reduction in range...Well there is not much one can do about
it...
I am planning to run my new Lycoming on autofuel and while the
manufacturers will tolerate that they go nuts about having any ethanol
in the fuel...Personally I am not convinced.
Frank
601 HDS Subaru 400 hours
RV7a FI Lycoming painting!
dredmoody(at)cox.net Guest
Posted: Wed May 31, 2006 9:09 am Post subject: Design for Alcohol Engine |
I believe that the issue is not about fuel boiling in the tanks. If the tanks are vented with the vent tube bevelled toward the oncoming air, the tanks should be pressurized slightly above the ambient pressure at which you are flying. Given our service ceiling limitation, if the fuel boils at that pressure there is little hope that any of us will make it back down alive.
The real life issue is in fact the fuel boiling (particularly if the fuel gets warmed by sunshine on the wings) when the pressure is significantly reduced by the pump having to suck it uphill in the fuel line. The bubble that forms in the line when fuel vaporizes tends to act as an obstruction in the line because when it reaches the pump, the efficiency of the pump on vapor is much less than on liquid. Also while the bubble is in the line and not going anywhere it requires the liguid fuel to pass around it. That results in a drastic reduction in the effective diameter of the lumen of the fuel line. So until the pump finally moves the bubbles through to the output side, the fuel flow is cut severely.
If the bubbles are not reabsorbed into the liquid fuel in the pressurized section of the line, they cause short periods of fuel starvation at the float bowl when they arrive.
Therefore, it's what happens between the tank and the carburetor that is of greatest concern to us inflight. Consider all the bubbles that are agitated into the fuel in the tank in turbulent conditions. They don't cause a problem unless the fuel level in the tank is low enough to suck some of them into the line. That's when the fun begins.
Locating a fuel pump in each wing near the tank is a good idea.
Ed Moody II
Rayne. LA
601XL / wings
Quote: | fuel system, no matter what the fuel is...That is pumps in the wing
of course.
p.mulwitz(at)worldnet.att Guest
Posted: Wed May 31, 2006 9:55 am Post subject: Design for Alcohol Engine |
There is another deadly issue with alcohol in aviation fuel. With
many states and the feds pushing use of alcohol we all face this
issue if we use anything but 100LL in our planes. This could be
really fatal if the availability of 100LL ends -- a likely event
since there is only one company in the world making the key
ingredient for 100LL Tetra Ethyl Lead.
Alcohol is a strong solvent. This means it will dissolve some of the
materials used to seal up our power plants and fuel storage/transport
systems. When this happens there are two potential problems. First,
the fuel is seriously contaminated with the dissolved
materials. Second. the seals and other parts needed to keep the fuel
flowing and contained disappear.
I have been trying to look into this whole problem since the warning
email from EAA asked for political action in my state (WA) to prevent
the existing bill requiring ethanol in all fuels from becoming
law. The law did not include avgas in its final version, but it
requires ethanol in all motor fuels other than avgas.
I don't have all the answers yet, but one show stopper is the
requirement in the Jabiru operating/maintenance manual that requires
use of alcohol free fuel. I believe this is typical of all aircraft engines.
Paul
XL wings
Quote: | The real life issue is in fact the fuel boiling (particularly if the
Posted: Wed May 31, 2006 10:31 am Post subject: Design for Alcohol Engine |
engines.
It is typical and the point you make about the seals is valid...BUT....
Alcohol proof seals are available. Indeed Airflow Perfromance uses seals
that are alcohol compatible in their aircraft engine FI systems. The
real problem posed by the makers of Lycoming clones is the
susceptability to vapour lock and thus "forbid" the use of Alcohol.
When I started digging on this issue I found what they were really
talking about was fuel boiling in the fuel injection lines...This is NOT
vapour lock...This is a "hot start" issue and taxiing issue.
Secondly all "proper" aircraft engines come with mechanical fuel pumps.
The undercolw temps on aircooled engines on the ground are usually WAAY
higher compared to a water cooled engine.
So now think about it...Mechaical fuel pump in a VERY hot cowl...What do
mechanical pumps do in a low wing airplane?...They suck...(in more ways
than one) on what is now WARM fuel. Yes I know they all have blast tubes
to cool them but they barely work to avoid VL on take off after a hot
taxi. This is a potentially deadly setup as warm fuel will boil with
almost no provacation from sucking.
It is hardly any wonder then that they are nervous of using an even
higher vapour pressure fuel than 92 Octane mogas, especially when the
thing coughs and splutters during taxi due to the injection lie boiling
issue. Of course there is normally an electric boost pump to augment the
mechanical pump but they cannot guarantee a prospective builder won't
try to avoid the complexity of the electric pump.
So I think the seal issue is resolvable (whether Jabauru will provide
such seals is another matter of course) and if electric fuel pumps are
used in the "hydraulically correct" place then alcohol might be much
less of a demon than the airplane engine makers proclaim it is.
Frank
cgalley(at)qcbc.org Guest
Posted: Wed May 31, 2006 11:13 am Post subject: Design for Alcohol Engine |
The fact that Alcohol is a solvent is NOT the problem. Alcohol with
moisture is a weak organic acid; corrosive.
If solvents were a problem, then there would not be any toluene in 100 low
lead as an octane enhancer. Toluene can and has taken the paint off
airplanes.
Cy Galley
EAA Safety Programs Editor
Always looking for ideas and articles for EAA Sport Pilot
noelloveys(at)yahoo.ca Guest
Posted: Wed May 31, 2006 11:50 am Post subject: Design for Alcohol Engine |
Paul:
I see you missed two points. I mention them only to reinforce your stand on
ethanol.
First alcohol has a natural affinity to water. This will allow water to
pass through your gascolator and enter the venturi of your carburettor where
it can freeze into ice. So the possibility of carb ice increases with
ethanol.
The second point is for those poor folks among which I'm one who presently
fly a two stroke engine. The lead in 100 LL ( that should be 100 Loaded
with Lead) will come out of suspension with the gas and deposit itself in
the roller bearings of our engines. This is a lot more dangerous than just
fouling the plugs!!
I noticed the group representing the people who build the ethanol plants
were saying that the cost of production of ethanol is less than gasoline.
I'll put it straight .... They are lying !! Unless the farms where the
sugar cane or corn is grown are growing the plants without the use of Diesel
tractors or harvesters and don't have to pump their water, the cost of
making ethanol will always be higher than fossil fuel and the green house
gasses given off by the production will be higher than if the ethanol
weren't made in the first place.
Noel
[quote] --
Posted: Wed May 31, 2006 12:00 pm Post subject: Design for Alcohol Engine |
Quote: | I don't have all the answers yet, but one show stopper is the
engines.
I'm willing to bet that the seals are not the only reason that Jabiru
requires the use of alcohol free fuel.
Another reason could be the amount of water vapour, or lack of it given off
when alcohol burns. Also any blow by could cause some interesting things in
the crank case. Oh yes alcohol has an affinity for water... How do you feel
about water condensing inside your crank case?
If ethanol was economically feasible for all, not just the people who erect
the ethanol plants I'd say we have to work around it. But .... The
production of ethanol causes elevated emissions of green house gasses and at
best it's a stop gap. Something worse than putting Chicory in coffee to
stretch out the coffee.
Noel
Posted: Wed May 31, 2006 12:11 pm Post subject: Design for Alcohol Engine |
Eight hours bottle to throttle should be for planes as well as pilots. For
any one who has composite fuel tanks believe me the solvent action of
ethanol is paramount. There is two ways of protecting your engines form the
effects of ethanol. Mix a bit of "Top Lube" in with the gas... Ethanol has
an affinity for water but it has a greater affinity for oil.
The other way is to remove the ethanol from the gas. Wash it out with water
which is easy to separate from the gas.
Noel
toluene in 100 low
airplanes.
Cy Galley
Posted: Wed May 31, 2006 12:24 pm Post subject: Design for Alcohol Engine |
Actually the major cause of camshaft failure in Lycomings is corrosion
from water that already collects in crankcase even using 100LL...At
least that is the theory...
It's a shame the political weight that has been thrown behind this
ethanol production nonsense. Probably too late to stop it now unless
something unpleasant happens...Like Chernobyl for instance.
I even heard sombody saying...WOW E85 is 15C a gallon cheaper!...yes and
it will get less miles for every one of those gallons too!
Frank
Gig Giacona
Posted: Wed May 31, 2006 1:23 pm Post subject: Re: Design for Alcohol Engine |
The problem with that is there will be a major change in the octane of the final fuel. If it was 87 octane with the Ethanol it isn't going to be 87 without the Ethanol.
noelloveys(at)yahoo.ca wrote: |
601XL Under Construction
Posted: Wed May 31, 2006 2:11 pm Post subject: Design for Alcohol Engine |
What you say is true.
What other octane boosters are available???
Noel
[quote] --
Bill(at)flyinmiata.com Guest
Posted: Wed May 31, 2006 3:06 pm Post subject: Design for Alcohol Engine |
toluene
Bill Cardell (TurboDog's Dad)
www.flyinmiata.com
1-800-FLY-MX5S
tech 970-242-3800
Posted: Wed May 31, 2006 3:57 pm Post subject: Design for Alcohol Engine |
Is Toluene available? I've only seen it discussed as a refinery additive.
Noel
[quote] --
naumuk(at)alltel.net Guest
Posted: Wed May 31, 2006 4:27 pm Post subject: Design for Alcohol Engine |
You can buy it in lab quantities from Fisher Scientific, if nowhere else.
Bill
Posted: Wed May 31, 2006 5:41 pm Post subject: Design for Alcohol Engine |
Most hardware and paint stores carry it. Works wonders in forced
induction applications to kill knock.
TurboDog's Dad
Bill Cardell
www.flyinmiata.com
1-800-FLY-MX5S
970-242-3800
randy(at)shadycreekoutlaw Guest
Posted: Wed May 31, 2006 5:45 pm Post subject: Design for Alcohol Engine |
It can be had at your local Sherwin-Williams paint store... I used to buy
it and use it as an additive in kart racing engines...
Randy
http://www.n344rb.com
601XL - Plans Building
Working on Wings
Posted: Wed May 31, 2006 5:55 pm Post subject: Design for Alcohol Engine |
I guess the last question is how much would you add to a gallon of gas to
increase the octane rating the 5 or so points lost by the removal of
ethanol??
I read somewhere that mixing kero 1:100 with gasoline will also increase the
octane rating about 5 points.
Noel
[quote] --
