keithmckinley
Posted: Wed May 30, 2012 1:03 pm Post subject: CJ-6 canopy seals |
concerning the fabric seal riveted to the metal retainer strip in the CJ cockpits. This strip does not seem to be riveted to the underlying canopy / front window bow. If that is correct how is it properly removed?
Thank you,
Harv
Posted: Fri Jun 01, 2012 5:08 am Post subject: Re: CJ-6 canopy seals |
Good afternoon
Drill the solid rivets out of the retaining strip and it will part company with the frame.
On the front cockpit its riveted to the front screen surround, and for the rear cockpit its riveted to the front bow of the sliding canopy but removal is the same for both.
I know of a firm (Based in the UK) called Woolies that can supply an exact replacement for this seal.
Rgs
Harv
jackpot
Joined: 13 Jul 2010 Posts: 65 Location: Las Vegas, Nevada
Posted: Fri Jun 01, 2012 5:19 am Post subject: CJ-6 canopy seals |
I believe I used soft (SO) rivets instead of the hard AN 470's when I reassembled mine as the metal is quite thin Worked well.
Gary G
CJ. N22YK
On Jun 1, 2012, at 6:08, "Harv" <martin.harvey(at)kbr.com> wrote:
Quote: |
Good afternoon
Rgs
Harv
http://forums.matronics.com/viewtopic.php?p=374464#374464
Posted: Fri Jun 01, 2012 10:27 am Post subject: CJ-6 canopy seals |
Did you build a jig to align the canopy frame after you drilled out the rivets and discarded the old glass?
Doc
On Jun 1, 2012, at 8:08 AM, "Harv" <martin.harvey(at)kbr.com> wrote:
Quote: |
Good afternoon
Rgs
Harv
Rich Langer
Posted: Sat Jun 02, 2012 3:35 am Post subject: Re: CJ-6 canopy seals |
Harv, I would very much like to know the part number from Woolies for the replacement canopy seal.
Thanks Rich
keithmckinley
Posted: Sat Jun 02, 2012 12:19 pm Post subject: Re: CJ-6 canopy seals |
he rivets in question do not go through any plexiglass and can be drilled out with the glass in place.
K
Harv
Posted: Sun Jun 03, 2012 11:44 pm Post subject: Re: CJ-6 canopy seals |
Rich
Here's the link to the Woolies website who sell the canopy seal.
I dont recall the exact dia of the seal that I used (please check before ordering) but this link is for the 8mm dia cross section seal. (They also sell 6mm and 10mm)
The skirt of the new seal needs to be cut back with scissors before fitting and I secured mine with some contact adhesive.
For re-assembly rivets I used the smallest automotive ali pull through ones which worked fine and look need and tidy.
http://www.woolies-trim.co.uk/p-1256-sponge-piping.aspx
Rgs
Harv
Rich Langer wrote: | Harv, I would very much like to know the part number from Woolies for the replacement canopy seal.
Thanks Rich |
