thane
Posted: Thu Jun 28, 2012 11:46 am Post subject: high oil PSI. |
After validating my oil PSI was ok with a mechanical gauge. I then began to hunt for the cause of my oil PSI going up to 99 PSI. What I found was that I had a failure in the one wire that comes off the sender. After replacing the whole wire the Oil PSI was back to normal. Initially, I replaced the connector on the sender and that did nothing. I had to go back to basics and get the old continuity tester out, and that was how I found the failed connector under the panel. Thanks to those who posted with helpful ideas.
Thane Sates
_________________ Working on finish kit: I hate fiberglass!! |
