ronko(at)att.net Guest
Posted: Thu Jul 05, 2012 7:52 am Post subject: What Paint Product Did You Use? |
Pulsar Builders,
I have a general question for those that painted their Pulsar themselves or those that had it done for them but know the product that was used. What paint finish product did you use? And, were you happy with the results or would you use something different if you had to do it all over again?
Thanks in advance to your responses.
Ron
barrynorman(at)comcast.ne Guest
Posted: Thu Jul 05, 2012 8:07 am Post subject: What Paint Product Did You Use? |
I used Matrix products and was very happy with it. It's held up very well over 6 years.
Barry
To: "Pulsar Builders" <Pulsar-List(at)matronics.com>, Pulsar-Aviators(at)yahoogroups.com
Sent: Thursday, July 5, 2012 11:51:43 AM
Subject: What Paint Product Did You Use?
Pulsar Builders,
Ron
MyronTruex(at)comcast.net Guest
Posted: Thu Jul 05, 2012 9:07 am Post subject: What Paint Product Did You Use? |
PPG two part epoxy paint. Then color sanded it till it looked like plastic. Easy to touch up or make major repairs.
From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of Ron Koval
Sent: Thursday, July 05, 2012 8:52 AM
To: Pulsar Builders; Pulsar-Aviators(at)yahoogroups.com
Pulsar Builders,
Ron
| Quote: | | http://www.matronics.com/Navigator?Pulsar-List | 0123456789
pulsar1(at)sbcglobal.net Guest
Posted: Thu Jul 05, 2012 9:41 am Post subject: What Paint Product Did You Use? |
We used PPG Concept 2000 base coat and clear coat. It's 12 years old and looks as good as when we painted it. If I had to do it over again I would use a one coat process, the clear coat just made it heavy, could have saved 10-12 pounds.
George
To: Pulsar Builders <Pulsar-List(at)matronics.com>; Pulsar-Aviators(at)yahoogroups.com
Sent: Thu, July 5, 2012 8:59:16 AM
Subject: Pulsar-List: What Paint Product Did You Use?
Pulsar Builders,
Ron
[quote][b][b]
leubanks(at)sunflower.com Guest
Posted: Thu Jul 05, 2012 10:59 am Post subject: What Paint Product Did You Use? |
I have used acrylic urethane for both Cars and planes and it works very well. Fairly easy to apply and repair if damaged. Minor scrapes can be buffed out, some chips can be repaired with a brush and color sanded to new.
The Imron is more for a professional to apply (dangerous stuff)but is extremely tough and a little more expensive. However if if you bang your plane hard enough to damage the paint you will probably dent the fuselage anyway.
My recommendation for do it your self painting is the acrylic urethane with the clear built in. PPG Concept is on my current Pulsar, Spies Hecker was used on the first and it was good but expensive. Most brands are pretty good but it's really the painter and lot's of hard work that makes them look great.
Larry
