Pro Seal Solvent
n146wb(at)cfu.net
PostPosted: Sat Jul 14, 2012 4:06 am    Post subject: Pro Seal Solvent Reply with quote
Does anyone know of a cleaner or solvent that is readily available that will cut Pro Seal?
Larry Bowen
PostPosted: Sat Jul 14, 2012 4:17 am    Post subject: Pro Seal Solvent Reply with quote
Try MEK.
Larry Bowen
Larry(at)BowenAero.com
n146wb(at)cfu.net (n146wb(at)cfu.net)> wrote:[quote]
t="_blank">http://www.matronics.com/Navigator?RV-List
tp://forums.matronics.com
Larry Bowen
RV-8 SOLD,
RV-7QB in progress...
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
Painless
PostPosted: Sat Jul 14, 2012 5:05 am    Post subject: Pro Seal Solvent Reply with quote
I had very good results with xylol. You should be able to find it in most hardware stores.
Jeff Orear
RV6A. N782P
Sent from my iPad
On Jul 14, 2012, at 7:16 AM, Larry Bowen <larry(at)bowenaero.com (larry(at)bowenaero.com)> wrote:
Try MEK.
Larry Bowen
[url=mailto:Larry(at)BowenAero.com]Larry(at)BowenAero.com (Larry(at)BowenAero.com)[/url]
[url=mailto:n146wb(at)cfu.net]n146wb(at)cfu.net (n146wb(at)cfu.net)[/url]> wrote:
Jeff Orear
RV6A N782P
Peshtigo, WI
ceengland(at)bellsouth.ne
PostPosted: Sat Jul 14, 2012 5:50 am    Post subject: Pro Seal Solvent Reply with quote
A lot of people (including me) use MEK, but IIRC, Flamemaster recommends Toluene (Methyl Benzene).
http://www.flamemaster.com/index.html
That's the solvent in the sealant.
Charlie
Kellym
PostPosted: Sat Jul 14, 2012 6:05 am    Post subject: Pro Seal Solvent Reply with quote
Ding, ding. We have a winner!
If you are just cleaning up, MEK is okay with all the precautions about
skin protection, not inhaling it, etc.
If you want to thin the sealant, toluene is correct.
If you just want a brushable consistency, get the A compound instead of
the B compound..it already has the correct amount of toluene in it.
A compound is better for covering rivet heads and as a topcoat over B
compound than using thinned B compound. Less likely to get air bubbles
and pin holes.
Kelly
Veteran of stripping and resealing Mooney fuel tanks
Charlie
Checked by AVG - www.avg.com
Kelly McMullen
KCHD
TimRVator(at)comcast.net
PostPosted: Sun Jul 15, 2012 3:47 am    Post subject: Pro Seal Solvent Reply with quote
I've heard good things about Polygone. Apparently it's made for this
purpose.
www.rpm-technology.com
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1104 hrs - sold
RV-10 N31TD -- 300 hrs
Warren Brecheisen said the following on 7/14/2012 8:05 AM:
Kellym
PostPosted: Sun Jul 15, 2012 6:42 am    Post subject: Pro Seal Solvent Reply with quote
Polygone is for removing cured pro-seal, available in gel and liquid
formulations. It breaks down the chemistry of the pro-seal and is used
to clean out a tank before resealing. It is NOT a thinner, and should
only be used where you want to remove cured sealant, not just a cleanup.
purpose.
Kelly McMullen
KCHD
