michael.cowan(at)lmco.com Guest
Posted: Thu Jul 19, 2012 12:14 pm Post subject: EXTERNAL: Re: RE: [Pulsar-Aviators] Pulsar weight restrictio |
Mine is S/N 503 – one of the last to leave San Antonio. I bought the SkyStar firewall fwd kit same as Jim Fillman and Bill Landucci.
Here is a tabulation of the specs I have:
Turbo Pulsar Pulsar XP Turbo Pulsar Pulsar XP
Power Plant Weights & Loads
Engine Rotax 914 Rotax 912 Empty Weight 660 lbs 630 lbs
Max. Power 115 HP 80 HP Useful Load 540 lbs 570 lbs*
Propeller 67 in. c/speed 60 in. gnd. adj. Gross Weight 1200 lbs 1200 lbs**
Turbo yes no Power Loading 10.44 lb./HP 15 lb./HP
Wing Loading 15 lb./sf 15 lb./sf
Performance Fuel Cpy. 28 gal. 28 gal.
Cruise Speed G Limits (tested) +6/-4 +6/-4
(at) Max. Cruise Pwr 180 MPH 150 MPH Seats 2 2
156 Knots 130 Knots Baggage Cpy. 60 lbs 60 lbs.
Stall Speed 49 MPH 49 MPH
43 Knots 43 Knots External Dimensions
Max. Climb 2000 fpm 1200 fpm Wing Span 25.0 ft 25.0 ft
Max. Op. Altitude 17,500 ft 15,000 ft Length OA 20.0 ft 19.5 ft
T/O roll 500 ft 800 ft Height OA 6.8 ft 6.3 ft
Ldg roll 800 ft 800 ft Wing Area 80 sf 80 sf
Range 900 sm 1000 sm Wing Aspect Ratio 7.8 7.8
Notes: airfoil is a NASA Langley MS (1)0313
*570 lb - (28 x 6.13 lb/gal fuel) - (1 x 7.6 lb/gal oil) - (1 x 8.5 lb/gal coolant) = 382.26 for pax + bags
- glide ratio is 12 to 1; 1.3 Vs0 = 60 mph
**gross determined by 6g static load to failure on spar (1200x6=7200 lb.); gear designed for 3g landing (at) gross
CG Llimits: 32.49 to 36.47 inches aft of datum - fwd. firewall flange
Regarding the breakdown of serial numbers, This is a note from John Melchert in my archives:
Tim Ribar apparently knew the answer here. Below is an excerpt from a
message he posted to the list 09/10/1999:
The breakdown of the kits is as follows:
AD Series I Pulsars (serial #'s 101 - 474) 374
AD Series II Pulsars (serial #'s 501 - 510) 10
Sky* Series III Pulsars(serial #'s 511 - 565) 55
Total 439 kits sold. AD published that 3/4 of the series I Pulsars were
XP's.
- Mike Cowan
From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of rwilhelm(at)dc.rr.com
Sent: Thursday, July 19, 2012 8:54 AM
Subject: EXTERNAL: Pulsar-List: Re: Pulsar-List: RE: [Pulsar-Aviators] Pulsar weight restrictions
My kit is s/n 529 from Skystar.
Ray. Pulsar III 3300
Sent from my Verizon Wireless 4GLTE smartphone
----- Reply message -----
From: barrynorman(at)comcast.net (barrynorman(at)comcast.net)
To: <pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)>
Subject: Pulsar-List: RE: [Pulsar-Aviators] Pulsar weight restrictions
Date: Thu, Jul 19, 2012 6:19 am
My kit came from Skystar, kit number 563.
Barry
From: "Bernard Wilder" <bernard.wilder2(at)gmail.com (bernard.wilder2(at)gmail.com)>
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Sent: Wednesday, July 18, 2012 5:32:59 PM
Subject: Re: Pulsar-List: RE: [Pulsar-Aviators] Pulsar weight restrictions
Barry,
Who did you buy your kit from ? ? ? ? ? Aero Designs or Sky Star.
Did antbody buy a kit from Soley ? ? ? ? ? ?
Bernie Wilder
On Wed, Jul 18, 2012 at 9:45 AM, <barrynorman(at)comcast.net (barrynorman(at)comcast.net)> wrote:
It's also 1200 for the Series III. Not sure if there was any difference in spar design from the II to the III. I know the Series III was heavier, mine came in at 711 with a 912 and a bit heavier for those that had the 914. I can't fly mine under 1200 pounds gross with full fuel, my wife and I and 60 pounds of luggage. That puts it at 1320.
Barry
From: "pilot623" <pilot623(at)gmail.com (pilot623(at)gmail.com)>
To: Pulsar-Aviators(at)yahoogroups.com (Pulsar-Aviators(at)yahoogroups.com), pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Sent: Tuesday, July 17, 2012 10:27:23 PM
As one of the few AD Series 2 Pulsar owners, I will add that the Series 2 carries a max gross weight of 1200 pounds.
Jim
From: Pulsar-Aviators(at)yahoogroups.com (Pulsar-Aviators(at)yahoogroups.com) [mailto:Pulsar-Aviators(at)yahoogroups.com (Pulsar-Aviators(at)yahoogroups.com)] On Behalf Of gregsmi(at)aol.com (gregsmi(at)aol.com)
Sent: Tuesday, July 17, 2012 7:16 PM
To: Pulsar-Aviators(at)yahoogroups.com (Pulsar-Aviators(at)yahoogroups.com); pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: [Pulsar-Aviators] Pulsar weight restrictions
All the discussion on Pulsar gross weights got me back into the manuals, news letters, and finally discussions with my favorite air craft designer. I know there has been some confusion about this, and if you have a plane that was purchased and built in stages, then this can be very confusing. So, here is the simple explanation.
Early Pulsar kits had a sitka spruce wood spar. Spar caps of unidirectional glass were added to the top and bottom of the spar for strength. On the earliest wood spars, the spar caps did not go all the way to the wing tip. The gross weight of a Pulsar built with these spars is 870 pounds. Latter in the program, the spar caps were extended to almost the wing tip. With that, the gross weight was upped to 900 pounds. 900 pounds is the max for the wood spar. This is exactly as stated by Alan Gill for Pulsar aircraft in the UK.
Later Pulsars had the composite spar and gross weight was increased to 1060 pounds.
Please note, gross weight limitation is solely determined by the spar material and spar caps. Composite wing skins and added glass to the spar sides does not increase the max gross weight.
I have looked in the Skystar manuals and not found the numbers for their aircraft, so will limit my comments to the Aerodesigns kits.
Flying an airplane over it's design limit is like driving a car, with smooth tires, at high speed on a wet surface. You may get away with it, until you hit a puddle, or in our case, turbulence. Turbulence adds G loading, and if you are over design limits, the wing could fail, not a good situation.
Needless to say, this is a major safety issue, and thus my concern. If you have any questions about this, please get back to me and I will try to get an answer for you.
Fly safe,
See you at Oshkosh,
Greg
Jabiru 2200 Pulsar
1500 hours
__._,_.___
Reply to sender ([email]GREGSMI(at)aol.com?subject=Re%3A%20Pulsar%20weight%20restrictions[/email]) | Reply to group ([email]Pulsar-Aviators(at)yahoogroups.com?subject=Re%3A%20Pulsar%20weight%20restrictions[/email]) | Reply via web post | Start a New Topic
Messages in this topic (1)
Recent Activity:
<![if !supportLists]>· <![endif]>New Members 1
Visit Your Group
[/url]
[url=http://groups.yahoo.com/;_ylc=X3oDMTJldmNzOWp0BF9TAzk3NDc2NTkwBGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnRyBHNsawNnZnAEc3RpbWUDMTM0MjU3MDU0OA--]Switch to: Text-Only, Daily Digest • Unsubscribe • Terms of Use
[/url]
[url=http://groups.yahoo.com/;_ylc=X3oDMTJldmNzOWp0BF9TAzk3NDc2NTkwBGdycElkAzEzMDMxMjUzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnRyBHNsawNnZnAEc3RpbWUDMTM0MjU3MDU0OA--]__,_._,___
arget=_blank>http://www.matronics.com/Navigator?Pulsar-Listp://forums.matronics.comblank>http://www.matronics.com/contribution |
0 1
2 3 4 5 6 7
8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1
)��ߢ{l�7�r�h�M4�MÂiǜ���z����.�'�N��[����I��Qh�锱�axÆï¿½ï¿½ï¿½r���^jÛ«z�Z�(������Ç�隟"�Û�X���,��Z����I�J��r���*'�!���y�܄:0�Zw�����ǂ��E��,���jwf��f��f��������i��0�f����r�(��Z�(��Ϻ[����m���� ���'���o�j��j�+>�lj����0�8�Ia�T1$���+y�\�{^�֥���j)ZnW���ayg���ơ������+�k&j��',r������+�k&j��',r��h���*'����ب�g�J+^N��*.~����zw���,��h�����jY^.+-٢��ky�m���� &j��',r��r��&�*'��i��0�f����r�(��(���n�b����ߢ{���n�r�f
