jds(at)taxesplusllc.com Guest
peter(at)sportingaero.com Guest
Posted: Mon Jul 30, 2012 1:10 pm Post subject: HUD for GA aircraft |
The big deal about HUDs is that they are focused at infinity with some fancy (heavy) optics. That way you look out the window and everything is in focus, data/target/bad guys laid on top of the scenery. This looks like a see through LCD (or similar), focussed on the plate. I'm not sure that would of huge benefit as you would be continually be re-focussing between the plate and the scenery. So $5000 for something that is only of real use when attacking those pesky ground targets, and then requiring a lot of focus shifting. It would be interesting to know what kind of lag there is between the world moving and the depiction on the glass responding - if it is more that 100ms (that is 0.1 seconds) then it is too slow to be of much use and will only be a hindrance.
Thanks for posting.
Peter
On 30/07/2012 19:45, Jerome Sipple wrote:
[quote] Just a fyi about an interesting blurb I saw in a gizmag email today about a new heads up display for GA aircraft. I have no connection with them, just passing along the info.
PAT Avionics shows G-HULP heads-up-display system for recreational aircraft
http://www.gizmag.com/pat-avionics-hud-recreational-aircraft/23477/?utm_source=Gizmag+Subscribers&utm_campaign=a4a140692e-UA-2235360-4&utm_medium=email
Jerry Sipple
Cozy MkIV project
dsleepy47
Posted: Tue Aug 07, 2012 7:15 pm Post subject: HUD for GA aircraft |
This: http://www.virtualhud.com/VirtualHud/VirtualHUD.aspx might be better for single engine tractor planes.
Deems
Date: Mon, 30 Jul 2012 22:09:28 +0100
Subject: Re: AeroElectric-List: HUD for GA aircraft
_________________ dsleepy47
N1491R |
