JLuckey(at)pacbell.net Guest
Posted: Thu Aug 09, 2012 12:04 pm Post subject: How to Select a Scope |
I’ve been considering purchasing an oscilloscope for hobby/trouble-shooting use. It’s been 30+ years since I’ve fiddled with scopes. I’m looking for counseling/guidance/recommendations.
Some things I want to do:
- Analyze the output of the crank angle sensor in my car – (currently having some starting problems, but I digress)
- I like to program micro-controllers and would like to do trouble-shooting & analysis
- Look at the wave-forms produced by an alternator
- Get the best bang for the buck
Questions: - I see devises advertised that are combo oscilloscope & logic analyzer. Are these as cool as they appear?
- How do I decide which frequency range I need? (It seems the higher the MHz rating of a device the higher the cost) Most of the micro-controllers that I work with are clocked around 4 MHz. I once heard that the rating of the scope should be 10x the signal you want to analyze. Is that true?
- What other criteria should I consider?
As always TIA, I look forward to learning something
Jeff Luckey
Norm Biron
Posted: Thu Aug 09, 2012 1:05 pm Post subject: How to Select a Scope |
Consider a scope with storage capability and get the fastest scope you can afford.
Norm
On Aug 9, 2012, at 3:12 PM, "Jeff Luckey" <JLuckey(at)pacbell.net (JLuckey(at)pacbell.net)> wrote:
Jeff Luckey
enginerdy(at)gmail.com Guest
Posted: Thu Aug 09, 2012 2:09 pm Post subject: How to Select a Scope |
I have one of these:http://www.tequipment.net/RigolDS1102E.html
It's "good" -- it's a pretty good scope for $400. Digital, storage, USB image and data capture, RS-232/USB computer control port.
You can also get a DS1052E for $350 if you want to drop down to 50MHz bandwidth for $50 less. I ended up getting the scope case for $50 as well.
There are definitely some glitches and usability hitches every now and then, but overall it's great for the money. But, if I had tons of money to blow, I'd definitely get an Agilent Infiniivision scope.
For the microcontroller work, you're going to get a lot more productivity mileage out of a Saleae Logic:
http://www.saleae.com/logic
For $150 not only will it capture 8 channels in parallel, but you can also assign channels to be decoded inline. Many serial formats are supported out of the box. For digital work, I highly recommend it. It will not read any analog inputs, however, so you'd need a scope for that -- but getting that kind of serial decoding in a scope tends to be expensive.
Good luck!
--Daniel
On Aug 9, 2012, at 3:02 PM, Jeff Luckey wrote:
Quote: | I’ve been considering purchasing an oscilloscope for hobby/trouble-shooting use. It’s been 30+ years since I’ve fiddled with scopes. I’m looking for counseling/guidance/recommendations.
Questions:
Jeff Luckey
Quote: |
href="http://www.matronics.com/Navigator?AeroElectric-List" style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?AeroElectric-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
klehman(at)albedo.net Guest
Posted: Thu Aug 09, 2012 6:39 pm Post subject: How to Select a Scope |
saelig.com is worth a look for value. I have an older PDS5022S which is
about all I need for playing with microcontrollers etc.
Ken
1. Analyze the output of the crank angle sensor in my car – (currently
2. I like to program micro-controllers and would like to do
3. Look at the wave-forms produced by an alternator
4. Get the best bang for the buck
Questions:
1. I see devises advertised that are combo oscilloscope & logic
2. How do I decide which frequency range I need? (It seems the higher
3. What other criteria should I consider?
Jeff Luckey
Posted: Thu Aug 09, 2012 8:43 pm Post subject: How to Select a Scope |
Thanks for all responses. Most have dealt w/ actual O-scopes.
What about scope/analyzers that connect to a computer via USB for control &
display?
Posted: Fri Aug 10, 2012 4:30 am Post subject: How to Select a Scope |
Jeff
While a logic analyser was very helpful with non microcontroller logic
circuitry I have not needed one since switching to playing with micros.
Note that I'm just a hobbyist.
I picked up a Velleman PCS100 multipurpose unit once that interfaces to
a parallel printer port. After playing for less than an hour I put it
back in the box and it has sat on the shelf undisturbed ever since. The
software seemed pretty good but the logistics of needing a computer plus
the scope plus AC power made it rather cumbersome and it was slow
compared to a $300. (at the time) digital scope from saelig.com. I still
may need a booster battery pack + inverter to use the saelig scope
anywhere other than my bench but at least those are small rugged
components that I usually have handy anyway.
I now assume that anything that interfaces with a computer has a life of
only a few years due to computer and operating system upgrades etc. that
eventually increase the hassle factor too high compared to replacing the
unit.
Simplicity is important for occasional hobbyist use. Anyway don't
underestimate the value of a stand alone (possibly hand held) scope. I
avoid anything with non standard rechargeable batteries though. Speed is
important for tracking down a glitch involving a spike at the corner of
a digital signal but for me that is a rare need with microcontrollers.
Usually I'm just looking for the correct polarity, phase, voltage, or
frequency if that makes sense to you.
Ken
What about scope/analyzers that connect to a computer via USB for control&
display?
