oh flier
Joined: 14 Aug 2012 Posts: 2 Location: Strongsville, OH
Posted: Tue Aug 14, 2012 7:16 pm Post subject: RV8A O360 low fuel pressure indication |
After way too many years building, today we finally started the Lycoming 0360 in my RV8A
I have the standard Vans steam gages and the fuel pressure gage never made it into the green with engine running and boost pump on or off. (same for engine off and boost pump on) gage off the peg but not in the green.
Fuel delivery test shows good delivery flow - 26 ghp.
Could this be a bad trasnducer or what have others in the group found to resolve this?
I have checked the listings and not found a good answer.
Gary Gembala [quote][b]
Kellym
Posted: Tue Aug 14, 2012 7:24 pm Post subject: RV8A O360 low fuel pressure indication |
Could you have the gauge intended for injected engines? Are there any
numeric values?
The correct gauge shows green from 0.5 to 8 psi and max value of 15
psi. With the flow you have, either you have the wrong transducer or
wrong guage or both.
Current catalog shows IE VFP 15 and IE 411AB transducer.
Kelly
On 8/14/2012 8:15 PM, GARY GEMBALA wrote:
| Quote: | After way too many years building, today we finally started the
the green.
to resolve this?
Gary Gembala
Checked by AVG - www.avg.com
KCHD |
oh flier
Posted: Thu Aug 16, 2012 4:53 pm Post subject: RV8A O360 low fuel pressure indication |
Yup, that the gage, will check transducer numbers Spoke to a friend in Florida, he cracked the line to the transduser and bled out the air.
