Main contactor to starter contactor connection…
mburbidg(at)gmail.com
PostPosted: Tue Aug 28, 2012 9:57 am    Post subject: Main contactor to starter contactor connection… Reply with quote
Hi Folks,
I'm using a short length of battery type cable made by B&C to connect my main contactor to the starter contactor. Both contactors are from B&C. The orientation of the terminal bolts on the contactors does not make for using copper bar easily.
I've enclosed a picture. My question is, do you the think the radius of the bend will put too much stress on this wire? If so, what would you suggest?
Michael-
[img]cid:1E3AD571-9E63-42E9-AC94-DB4885A68A94[/img][img]cid:598314EF-E5BB-4D2B-A48E-6CB80AF68218[/img]
 Filesize:  24.57 KB
 Viewed:  1074 Time(s)
 Filesize:  31.42 KB
