Posted: Sun Sep 09, 2012 4:35 am Post subject: IO360B / O360A Fuel pump gasket |
I am adding a fuel pump cooling shroud to help prevent vapor lock.
The fuel pump gasket tore around the bolt-hole as I took the pump off to add the cooling shroud.
Anyone know where to get a replacement gasket?
It looks like an old chevy fuel pump gasket – in fact the pump has AC on the top…..
Thanks in advance,
Ralph
RV6A N822AR – reassembling after inspections brought on by the tornado induced prop strike by my hangar door.
Gary.A.Sobek
Posted: Sun Sep 09, 2012 4:57 am Post subject: IO360B / O360A Fuel pump gasket |
www.aeroinstock.com is where I purchased mine at.
GarySent from my iPhone
On Sep 9, 2012, at 5:39 AM, "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
[quote] <![endif]--> <![endif]-->
Thanks in advance,
Ralph
Kellym
Posted: Sun Sep 09, 2012 5:10 am Post subject: IO360B / O360A Fuel pump gasket |
Any place that carries standard Lycoming parts and gaskets will have it.
On 9/9/2012 5:57 AM, RV6 Flyer wrote:
| Quote: | www.aeroinstock.com <http://www.aeroinstock.com> is where I purchased
mine at.
Gary
> on the top…..
> Thanks in advance,
> Ralph
���~��,�g���M4�G�q���z����.�'�
8ER��&j)E���K��j��',.+-歺
��5�h����,xzf�ȸ���b�+bz�.r�.+-Rҹ��*m���!��y�܄:0�Zw�����ǂ��E��h��y�ݚ�!��!������i��0�f����r�(��Z�(���T���m����
���'���o�j�j�+ER���M� $�NEC&z
�j�(�ק��l��ڊV����j�^Y�Ţ��������ߢ���f����r�(�m��ߢ���f����r�(����*'����ب�g�J+^8�L���+ʋ���ޮ����i��1�m�������)j�|����&j��',r��r��&�*'��i��0�f����r�(��(���n�b���ߢ{���n�r�fl===
KCHD |
krhooper(at)gmail.com Guest
Posted: Sun Sep 09, 2012 5:26 am Post subject: IO360B / O360A Fuel pump gasket |
If all else fails or you want to finish today, get some gasket material and cut out your own.
Randy Hooper
Sent from my iPad
On Sep 9, 2012, at 7:38 AM, "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
Thanks in advance,
Ralph
cs.com
matronics.com/contribution
