ianxbrown
Posted: Mon Sep 17, 2012 7:39 am Post subject: Avoiding a Flip Over? |
Flyers and builders of Van's RV "A" models, I flipped my aircraft over and
face a major rebuild. I wanted to send a message to the digest to give a
heads-up to those of you who don't find the time to dwell in the forums.
There is a device that could save your lives and could have saved major
expense for me. It's called the AntiSplat device from AntiSplatAero. I'm
convinced that my flip over could have been avoided if I'd had this. At the
same strip two days later the identical aircraft arrived, an RV-9A, and they
had AntiSplat fitted and had no problems on this somewhat bumpy grass strip.
I could also improve my piloting skills, but that's a different chapter. At
least the five-point harnesses did a great job. Snug 'em up tight folks,
and carry that escape tool. It turns out that when you're upside down the
canopy won't move, slider or tip-up, and the canopy is already smashed so
the tool you need to get out is something that will snap off plexiglass.
Also, don't expect to have the presence of mind to pick up your favourite
escape tool before you undo your harness and land on your head, which might
just disorientate you a bit, or even turn you around.
A really pleasant surprise was to discover that the RV vent design results
in no fuel loss when inverted accidentally. We saw a small amount drain out
when the plane was righted, but while inverted it's good to take stock of
the situation in the knowledge that you probably don't have fuel leaking.
Ian Brown
RV-9A C-GOHM
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Mon Sep 17, 2012 7:55 am Post subject: Avoiding a Flip Over? |
Just curious if you had the MATCO "fix" installed, replacing the designed
axel. When Alex Peterson diagnosed the problem with the nosewheels as
designed a few years ago, and a fix was made available, suddenly a lot of
reports of nose-gear flips seemed to disappear, pretty much confirming -- it
seems to me -- Alex's diagnosis that the design from Van's imposes a
"breaking action" with the puck that seemed to be alleviated with that fix.
I've heard tood things, too, about the AntiSplat, but I'm wondering if my
anecdotal evidence of a decline in flips suggests a fix already existed that
worked?
So sorry about your flip, but glad you're OK.
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
Hopperdhh(at)aol.com Guest
Posted: Mon Sep 17, 2012 2:30 pm Post subject: Avoiding a Flip Over? |
Hello Ian,
Thanks for the post. I can really sympathize with you. I had a nose-
over about 4 years ago. Took about $10K and 3 months to get
back in the air. I slid off my runway making a turn in wet grass. Why
didn't I just shut it down? My thought was if I get this thing stuck
it will take me a half hour to get it out! I don't blame the nose
gear design for my poor groundmanship, but several other flip-overs
have happened around here which have made me afraid of my
wonderful RV -- to the extent that I don't want to offer rides to friends.
I just ordered the AntiSplat Nose Job for my RV-7A
based on reading not just your post but also reading posts and watching
the videos linked from the Vans Air Force site. I was off list for the past
couple of years so I wasn't aware of this device until now. It sure looks
good. This looks like the best improvement to the fragile nose
gear design out there so far. If any of you nose wheel drivers haven't
seen the videos mentioned above, you should. The one about the test
fixture is especially enlightening.
Anyone flying an -A model RV needs to be extremely careful because
this type of accident happens when you least expect it. In my case I
didn't flip clear over, but still had to tear the engine down and replace the
propeller, engine mount, firewall and lower skin to fix the airplane.
Others around here have not been so lucky. Two recent nose-overs
resulted in total airframe losses.
Thanks again Ian for the post and best of luck as you start the rebuilding
process. Seriously, if I had it to do over again, I would take this
opportunity to convert it to a tail dragger.
Dan Hopper RV-7A
IO-360 about 500 hours since 2004.
ianxbrown
Posted: Tue Oct 16, 2012 7:11 am Post subject: Re: Avoiding a Flip Over? |
Thanks for the feedback and sympathy. I had not been a regular visitor to the forums, but I do receive the daily digest. I was unaware of the Matco "fix" but I'm a bit more confident in the AntiSplat bearing replacement, even though it's a bit more expensive. There is no adjustment of the bearing tightness and it's sealed for life.
I think one factor in all of this is that anyone who flips over probably places a higher priority on safe technique.
I have the good news that I was able to get the prop repaired, and the engine has no visible interior damage. The Magnaflux testing will be the definitive answer but I'm looking at a lot less cost for the engine and prop than I feared. $1,000 for the prop and $2,000 for the motor. Initial fears were $3k for prop and $5k for motor.
You probably live with regrets too. Mine is "why the heck didn't I overshoot if I was going to land half way down the runway?"
Bob Collins
Posted: Tue Oct 16, 2012 8:39 am Post subject: Avoiding a Flip Over? |
///I think one factor in all of this is that anyone who flips over probably
I couldn't disagree with this statement more. I think one might say people
who haven't flipped over probably place a higher priority on safe technique.
St. Paul, Minn.
ianxbrown
Posted: Wed Oct 17, 2012 5:38 am Post subject: Re: Avoiding a Flip Over? |
Bob, I think you misunderstood. I was saying AFTER an accident like this one is more likely to place a HIGHER priority on safe landing technique than one did before the accident... I'm not sure that those who never had an accident like this can be assumed to be safer just because it didn't happen.
