jeff(at)westcottpress.com Guest
Posted: Mon Oct 29, 2012 9:29 am Post subject: Rechargeable Screwdrivers |
I've just burned out my second one. Any suggestions?
Jeff Carpenter
40304
Priming my wheel pants
flying-nut(at)cfl.rr.com Guest
Posted: Mon Oct 29, 2012 9:44 am Post subject: Rechargeable Screwdrivers |
Yeah. Buy a good quality one .... major brand name. Drill pilot
holes. Use Boelube on screws going into nutplates. Don't let it bog
down .... locked-rotor current is really high.
Linn
On 10/29/2012 1:28 PM, Jeff Carpenter wrote:
Jeff Carpenter
40304
Checked by AVG - www.avg.com
robin(at)PaintTheWeb.com Guest
Posted: Mon Oct 29, 2012 9:59 am Post subject: Rechargeable Screwdrivers |
I purchased these based on an RV-List recommendation and have been very happy with the pair. I have not used the impact driver much as I have another impact driver but the drill has been really nice to use and the units are smaller/lighter than a standard drill drivers so you fatigue less when working long hours.
http://www.amazon.com/gp/product/B0045JK3GI/ref=oh_details_o00_s00_i00
Robin
Posted: Mon Oct 29, 2012 10:04 am Post subject: Rechargeable Screwdrivers |
I guess I should qualify that... I'm looking for a make/model suggestion. An employee of mine burned the last one out trying to get a fat deck screw out of an old wall stud.
I haven't been happy with what I've had so far. The most recent, a Black and Decker, had a poorly located reverse switch that always got bumped at just the wrong time.
On Oct 29, 2012, at 10:43 AM, Linn wrote:
Yeah. Buy a good quality one .... major brand name. Drill pilot holes. Use Boelube on screws going into nutplates. Don't let it bog down .... locked-rotor current is really high.
Linn
> Jeff Carpenter
> 40304
> No virus found in this message.
Posted: Mon Oct 29, 2012 10:29 am Post subject: Rechargeable Screwdrivers |
I had to go out to the shop and check .....
All of the ones I use most are B&D ..... I have the 3.6V versapak screw
driver and two drills, one 18V and one 24V. I also have a 1/2" corded
Makita hammer/drill that I use for heavier work. I wouldn't buy a
screwdriver that didn't have a replaceable battery. The battery drills
far outlast their battery packs.
Linn
On 10/29/2012 2:04 PM, Jeff Carpenter wrote:
> Linn
>> Jeff Carpenter
>> 40304
rv10pro(at)gmail.com Guest
Posted: Mon Oct 29, 2012 11:33 am Post subject: Rechargeable Screwdrivers |
One of the best power tools I have ever purchased was a Black & Decker 1/4" drive ratchet It is Lithium Ion powered and holds a wonderful charge. If they just make an Apex driver that is similar construction, you could use all of the 1/4" hex bits now created. The cheapest bit set is the HF drill bit kit which fits right in the 1/4 drive hex.
John Cox
On Mon, Oct 29, 2012 at 10:28 AM, Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
[quote]--> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)>
Jeff Carpenter
40304
http://forums.matronics.com
le, List Admin.
rv10flyer(at)live.com Guest
Posted: Mon Oct 29, 2012 12:48 pm Post subject: Rechargeable Screwdrivers |
Very nice indeed!
On the price side exteme, I paid $15.99 at lowes for a kobalt 12v drill and it has lasted 2 years of plenum, cowl on and off work
Once I break it I'll look for another one.
Robin
n223rv(at)wolflakeairport Guest
Posted: Mon Oct 29, 2012 4:48 pm Post subject: Rechargeable Screwdrivers |
I purchased this one recently and I like it. It directly takes an apex bit, has very low torque settings, and a light. Plus it's pretty cheap! The downside is the light only comes on when the drill is turning (it would be nice if a half pull would turn it on first). Overall a good value in my opinion.
http://www.homedepot.com/h_d1/N-25ecodZ5yc1v/R-203233910/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=ryobi&storeId=10051#.UI8iKRK9LCQ
-Mike Kraus
On Oct 29, 2012, at 4:47 PM, Pascal <rv10flyer(at)live.com (rv10flyer(at)live.com)> wrote:
[quote]--> RV10-List message posted by: Pascal <rv10flyer(at)live.com (rv10flyer(at)live.com)>
Very nice indeed!
On Oct 29, 2012, at 10:58 AM, Robin Marks <robin(at)PaintTheWeb.com (robin(at)PaintTheWeb.com)> wrote:
[quote]--> RV10-List message posted by: Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)>
Robin
Posted: Mon Oct 29, 2012 7:33 pm Post subject: Rechargeable Screwdrivers |
I went to Lowes today and was told that one I bought was on clearance, back
when I bought it. They are no longer available or sold by Lowes.
There was a black and decker one there but it was more expensive. the best
one was the dewalt and the Porter cable, as Robin mentioned. Both right
around 100 range (without the battery)
partner14
Posted: Mon Oct 29, 2012 7:45 pm Post subject: Rechargeable Screwdrivers |
Sam Butler here in Pecan bought one from Costco,,, cheap and works great.
Sent: Monday, October 29, 2012 10:32 PM
Subject: Re: Rechargeable Screwdrivers
--> RV10-List message posted by: "Pascal" <rv10flyer(at)live.com (rv10flyer(at)live.com)>
40636 |
mauledriver(at)nc.rr.com Guest
Posted: Mon Oct 29, 2012 8:50 pm Post subject: Rechargeable Screwdrivers |
More tools can be better.
I picked up a small lithium one from Costco 6 years ago. I think it drove every screw on my 10 twice. It's relatively fast, one speed, no ratchet. Still use it for disassembly only.
Picked up a small Ryobi with ratchet ( not sure of proper term). I now use it for all screws unless the faster Costco is at hand for disassembly. I like the ratchet for a consistent Assembly.
I don't use the little drivers or any electric for drilling. Air only for me.
Anyway, I just did 12 hours of traveling the past week including some ops around Sandy's perimeter. The 10 Rocks!
Bill
Sent from my iPad
On Oct 29, 2012, at 11:44 PM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
[quote]Sam Butler here in Pecan bought one from Costco,,, cheap and works great.
From: Pascal <rv10flyer(at)live.com (rv10flyer(at)live.com)>
Posted: Tue Oct 30, 2012 11:36 am Post subject: Rechargeable Screwdrivers |
From Michael, this is the Ryobi referenced below:
Yes, it would be nice if the light could be activated before activating the driver but still nice.
...but the 9.6 volt advertised on the same page is a waste of $$$. Not a good screw driver, not enough power for drilling, too little capacity between charges.
Bill
On 10/30/2012 12:49 AM, Bill Watson wrote:
[quote] More tools can be better.
I picked up a small lithium one from Costco 6 years ago. Â I think it drove every screw on my 10 twice. Â It's relatively fast, one speed, no ratchet. Â Still use it for disassembly only.
Picked up a small Ryobi with ratchet ( not sure of proper term). Â I now use it for all screws unless the faster Costco is at hand for disassembly. Â I like the ratchet for a consistent Assembly.
I don't use the little drivers or any electric for drilling. Â Air only for me.
Anyway, I just did 12 hours of traveling the past week including some ops around Sandy's perimeter. Â The 10 Rocks!
BillÂ
