sean(at)stephensville.com Guest
Posted: Mon Nov 26, 2012 7:27 am Post subject: Initial Brake Fluid Qty |
Getting close to filling up the brake lines. Going to place an order
and was wondering how much fluid it takes to initially fill the lines.
Want to order enough for that and some spare.
-Sean #40303 (attaching all the engine doo dads)
rv10flyer(at)live.com Guest
Posted: Mon Nov 26, 2012 8:16 am Post subject: Initial Brake Fluid Qty |
not much at all. I bought a small bottle from AS and still had 1/2 of the
fluid left when I filled it all and one side that had an air pocket, twice.
gnolin(at)sbcglobal.net Guest
Posted: Mon Nov 26, 2012 8:38 am Post subject: Initial Brake Fluid Qty |
I filled my brakes a few months ago. It took about a quart, spills and all.
RV10 soon
AKA
G. Hank Nolin, P.E.
832-640-6284
www.salestaxexemptions.com[url=http://www.salestaxexmptions.com/][/url]
"Science, freedom, beauty, adventure--aviation offers it all."
Charles A. Lindbergh
--- On Mon, 11/26/12, Sean Stephens <sean(at)stephensville.com> wrote:
Subject: Initial Brake Fluid Qty
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Monday, November 26, 2012, 9:26 AM
--> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
Getting close to filling up the brake lines. Going to place an order and was wondering how much fluid it takes to initially fill the lines. Want to order enough for that and some spare.
Thankbsp; November is the Annual List Fund Raiser. Click on
p; --> http://www.m=============
| [quote][b]
johngoodman
Posted: Tue Nov 27, 2012 6:30 am Post subject: Re: Initial Brake Fluid Qty |
The small 4 oz bottle from Aircraft Spruce "should be enough"... depending on how much you spill. Also, you might need a little more in your pump/bleeder (whatever you use to pump it up from the bottom). Do you have a friend that already has a pump setup? If so, borrow his and replace what you use with the 4 oz bottle. Otherwise, get more and look for a pump system.
rv10flyer
Posted: Tue Nov 27, 2012 6:44 am Post subject: Re: Initial Brake Fluid Qty |
10 oz.
_________________ Wayne G. |
johngoodman
Posted: Tue Nov 27, 2012 7:04 am Post subject: Re: Initial Brake Fluid Qty |
Actually, 10 oz might be right. Looking back, my container from Spruce was 16 oz, not 4 oz.
Kelly McMullen
Posted: Tue Nov 27, 2012 7:07 am Post subject: Initial Brake Fluid Qty |
Figure a pint bottle as a minimum, to allow for spillage, and to have some to top off when the pads wear and more fluid is needed in the calipers.
Think seriously about getting the high temp, fire resistant fluid. MIL-PRF-83282D
available http://www.skygeek.com/royco-782-synthetic-fire-resistant-hydraulic-fluid.html
and elsewhere, but I think 1 Qt is about the minimum you will find.
On Tue, Nov 27, 2012 at 7:44 AM, rv10flyer <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)> wrote:
[quote] --> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)>
10 oz.
Wayne G.
12/01/2011
TT= 95
http://forums.matronics.com/viewtopic.php?p=389111#389111
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Tue Nov 27, 2012 7:22 am Post subject: Initial Brake Fluid Qty |
Thanks everyone. I ordered the quart of high temp from SkyGeek along
with mineral oil and some dehydrator plugs.
-Sean
On 11/27/12 9:06 AM, Kelly McMullen wrote:
| Quote: | Figure a pint bottle as a minimum, to allow for spillage, and to have
calipers.
MIL-PRF-83282D
available
<mailto:wayne.gillispie(at)gmail.com>> wrote:
<wayne.gillispie(at)gmail.com <mailto:wayne.gillispie(at)gmail.com>>
10 oz.
Wayne G.
12/01/2011
TT= 95
le, List Admin.
