Craymondw(at)aol.com Guest
				 Posted: Wed Dec 19, 2012 6:35 pm    Post subject: Glasair 2S W&B |
				Sounds great. I was the first to complete and warned Stoddard Hamilton of a  potential C.G. problem. They had a professional weight the plane and decided to  convert to the Super 2S. One poor builder phoned me in 1991 to say that he  just completed a RG 2S and had a stall speed of 90MPH!!! Having a full panel  with two radios, a 200HP engine and a constant speed prop saved my butt. My  CD fell within limits. Later removing the heavy lacquer primer and Centuri paint  in 1996 made a big difference. After I removed all the paint I swept it into a  bag and weighed it and was surprised to see it weighed around forty five  pounds. I even sanded down the gell coat to a thinner thickness.  Plus  I put the plane on a diet by installing lighter upholstery and hard ware were  ever I could. I installed a far lighter battery and starter motor that  saved a lot of weight.  Doing that dropped the empty weight from 1415  pounds to a little over 1325 and moved the CG forward. I understand when a  heavy paint is used it adds weight to the aft.
                                                           Chuck Raymond
   In a message dated 12/19/2012 1:56:26 P.M. Eastern Standard Time,  jonlaury(at)impulse.net writes:
   	  | Quote: | 	 		  -->    Glasair-List message posted by: "jonlaury"    <jonlaury(at)impulse.net>
 Hi Chuck,
 That's really funny that    you contacted me about this because when I was guesstimating where my CG would    fall using the 6cyl 220 Franklin engine, someone gave me your W&B numbers    for your fixed Tri-gear. 1275 #'s EW if I recall.
 To answer your    question, my 2STD CG ended up being right on the dot. See the    attached.
 I thought that the airplane would be nose heavy from the 6    cyl engine so I moved it as aft as I could and used a 29# Whirlwind 151 CS    prop. Battery on the FW. I have the Super II horizontal and I moved my wing    aft. SL 30, transponder, audio panel, Trio Pro, AFS 4500 panel. Full conformal    foam (heavy) upholstery, floorboards in baggage (makes it flat).
 I    built it as an FT with all the hardpoints and FW beefing for the nose gear    trunnion. And then I got over all the fear-mongering re the TD (always my    first choice) and found some Grove aluminum TD gear in Barnstormers for a song    and converted.
 I weighed control surfaces before and after painting    with Southern Polyurethane single stage white, topped with clear  and the    difference was just a few ounces. I can't imagine paint on the whole plane    amounting to more than 15#'s or so.
 Hope this helps.
 Best,
 John
 (805) 686 4331
 Read this topic    online    here:
 http://forums.matronics.com/viewtopic.php?p=390704#390704
 http://forums.matronics.com//files/n20td_wandb_work_sheet_370.xlssp;  bsp;             (And Get Some AWESOME FREE  o find  ifts  bsp;   lder's  LP     you for  ;                        -Matt Dralle,    List   the  ies  ay                 - MATRONICS WEB FORUMS
  |  | - The Matronics Glasair-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Glasair-List |
