Posted: Mon Jan 21, 2013 5:14 am Post subject: Z-13 and Dead Battery (CORRECTION) |
| Quote: | But ANY time the battery suffers a total discharge it should
be recharged and cap checked on the ground to make sure it
meets your design goals for minimum battery performance. In
any case, with a battery taking heavy recharge currents from
the engine driven power sources, I would not turn on much
in the way of electro-whizzies until the low volts warning
light has been out for 5-10 minutes. If the ship's voltmeter
says anything over 11 volts, electro-whizzies should work as
advertised, but leaving the ground WITHOUT assurances that
the battery is taking on a charge is NOT good pilotage. <=========
