Dick Maddux
Posted: Sun Jan 20, 2013 6:25 am Post subject: reverse prop rotation at shut down |
I didn't know quite what to call this. As many of you know I have had a on going problem with the prop rotating backwards at shut down sometimes. It's not really diseling (I don' think) ..Maybe it stops at the top of the pawl in the gearbox and flips backwards. I don't know. I have had the carbs redone ,gearbox rebuilt,prop replaced,borescoped cylinders,etc.
The only thing that appears to stop this from happening is to pull the throttle back to about 1200 rpm (or much less) at shutdown.
Anyway, my question revolves around the possibility of ingesting air into the lifters. My prop has gone around as much as 3 revolutions in reverse direction. So in each case I have done the lifter check making sure I have no more than .020 clearance between the push rods and the rocker arm (per the service inst)
I have done this so many times that I am seriously considering attaching my cowl with Velcro !
At no time have the clearances on the valves exceeded the parameter.
I highly suspect that rotating you prop backwards,providing there are no open oil lines,etc is not the big deal that Rotax makes it out to be. Obviously I am not going to do it on purpose but 3 full revolutions backward and no air ingestion ? On at least 10 occasions ?
Stupid engine !..but it really does run well other than this quirk,it starts at one blade,smooth... it's just perplexing.
Dick Maddux
912 UL
rlborger(at)mac.com Guest
Posted: Sun Jan 20, 2013 8:04 am Post subject: reverse prop rotation at shut down |
Hi Dick,
I notice that you say: "The only thing that appears to stop this from happening is to pull the throttle back to about 1200 rpm (or much less) at shutdown." That's exactly how I shut my engine down. I let it idle at 1800-2000 RPM for a bit to cool the turbo and just kind of quiet things down. Then for shutdown I pull the throttle all the way back, let the engine drop to about 1200 RPM and as it hits that 1200 I kill both ignition switches to stop. That's the only time I let the RPM go below 1800.
Some folks may ask why I even have the throttle set to allow RPM below 1800. Good question. I had it set that way originally and found out that the darn airplane (as a monowheel) didn't want to come down or land with that much power being made. I could slow-flight a thousand feet down the runway in ground effect at 1800 RPM before it'd settle in. So I set the throttle to allow me retard it below that 1800 idle on final approach. Then, with the throttle fully back, the aircraft descended nicely showing 1800 RPM (rather than 2100 at the previous setting) and at the flare I bump the throttle to keep the RPM at a satisfactory level and I could land without coasting the full length of the runway. Things appear to have changed a bit now that it's a tri-gear. I have to fly it a bit more to see just how it has changed.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
Dick Maddux
912 UL
BARRY CHECK 6
Posted: Sun Jan 20, 2013 8:10 am Post subject: reverse prop rotation at shut down |
Guys:
I am on the Rotax list because I am very interested in getting a Ch-601 and many of them have Rotax engines. I would jump at the chance of getting one with a O-200 or O-235. I just can not justify in the slightest a Rotax engine, because of issues like Dick is reporting. I may be forced into a Rotax, only to swap it out.
But, Dick, I think I have a suggestion that may help in your situation. Set the engine at high idle - KILL the MAG/Spark first - Then the fuel. If the problem still occurs then look at the possibility of a Hot Spot (Pre-Ignition)
Jerking an engine in the reverse direction is not a good thing no matter how you look at it. Not even good for the airframe.
Barry
On Sun, Jan 20, 2013 at 9:24 AM, <Catz631(at)aol.com (Catz631(at)aol.com)> wrote:
[quote] I didn't know quite what to call this. As many of you know I have had a on going problem with the prop rotating backwards at shut down sometimes. It's not really diseling (I don' think) ..Maybe it stops at the top of the pawl in the gearbox and flips backwards. I don't know. I have had the carbs redone ,gearbox rebuilt,prop replaced,borescoped cylinders,etc.
Dick Maddux
912 UL
ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
tp://forums.matronics.com
brian.davies(at)clara.co. Guest
Posted: Sun Jan 20, 2013 9:28 am Post subject: reverse prop rotation at shut down |
Barry,
If you treat a Rotax like a Lyc/Cont it will protest. Switching off the ignition at high idle will cause the problem being described. I was taught to close the throttle completely and then switch off one mag, and then both mags. That way the engine stops without kick back. The gearbox arrangement prevents the engine stopping softly like a Lycoming. It will always stop suddenly as if it has seized. Once you get used to it, it will not give you any problems.
Brian
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE
Sent: 20 January 2013 16:10
To: rotaxengines-list(at)matronics.com
Subject: Re: reverse prop rotation at shut down
Guys:
Barry
Dick Maddux
912 UL
| Quote: | | < - The RotaxEngines-List Email Forum Use the Matronics List Features Navigator to browse | 0123456789012
Checked by AVG - www.avg.com
Version: 2013.0.2890 / 01/19/13
Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Sun Jan 20, 2013 5:50 pm Post subject: Re: reverse prop rotation at shut down |
Hi all.
It does seem to have a lot of problems Staring and Stopping, seems more have problems than don,t.
The design, the prop coming to a sudden stop, which is normal for the Rotax engine, so it may be, but my common scene tells me it not an ideal way an engine should stop,
I run my engine for 3 minutes at idle to cool the turbo down, and stop it at the lowest RPMs i can achieve.
Your problem sound like Pre ignition the engine it hot.
My starting Kick back is Detonation of the fuel, or the timing to far in advance and the piston not getting over TDC.
During crank at starter speed i can not see to much hot air being made.
Only me making it,saying Stupid engine.
My Prop is a PV 50
Just found the receipt for the battery, 22/09/2009
ODYSSEY EXTREME RACING BATTERY 25 (16 APP/HRS-680 AMPS CRANK) priced £100 now is that a good battery ?? it seems to turn it over OK ?
What you need is the old model aeroplane starter clipped to the spinner then the little engine had no choice which way it was going to go, Remember those days, or perhaps its just us old boys that made models on the end of a wire.
I would guess my plane has the standard fitted starter motor.
When i get round to it i will fit a soft start but for me it means fitting a starter button.
Alan
max8992
Posted: Mon Jan 21, 2013 1:00 am Post subject: reverse prop rotation at shut down |
Hi there all !
Brian says : “If you treat a Rotax like a Lyc/Cont it will protest... I was taught to close the throttle completely and then switch off one mag, and then both mags ...Once you get used to it, it will not give you any problems”.
Coming from old Lyc / Conti world I happen to discover the same trick to shut down with my first 912ULS on the Europa and apply it now to the second on my MCR4S (also a bit surprised by its attitude at starting I’m still considering to implement a “soft start kit”). It seems not to have an impact on the cycle-life, both running smoothly after more than 450 hours.
Max Cointe
mcointe(at)free.fr (mcointe(at)free.fr)
F-PMLH Europa XS_TriGear
Kit #560-2003 912ULS/AirmasterAP332 450 hours
F-PLDJ Dyn’Aéro MCR 4S
Kit #27-2002 912ULSFR/MTProp MTV7A 1550 heures
_________________ Max8992
Europa XS #560 F-PMLH |
Alan Carter
Posted: Mon Jan 21, 2013 2:28 am Post subject: Re: reverse prop rotation at shut down |
Hi.
450 hours, !
My Honda Civic did 330,000 miles god knows how many hours that would be over 18 years and was still as good as the first day i had it .
Its an engine, should run all its life without any major problems.
Why do you all seem the think an areo engine should be any different
Alan.
Posted: Mon Jan 21, 2013 4:47 am Post subject: reverse prop rotation at shut down |
Alan,
Aero engines are operated in a different manner to auto engines. Auto engines normally don't run at more than 25% of their rated power. The engine in my Ford F-150 is capable of 450 ft-lbs of torque and 390 HP at 5000 RPM but rarely runs over 2500 RPM. It's just lazing along at highway speeds. And they very rarely, if ever, are called on to provide 100% power.
Aero engines normally run in the 65%-100% range of their power. And Aero engines are routinely operated at 100% power for extended periods of time during takeoff and initial climb out. Engines with fixed pitch props always climb at 100% power. Engines with C/S props may drop back to 90% for extended climb. Then in cruise they run at 65%-75% or greater power continuously. As a result there's considerably more operating stress on an aero engine than an auto engine.
And that doesn't take into account the differences in operating environment at sea level to 6000 feet vs sea level to 12,000 feet and sometimes much higher.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Jan 21, 2013, at 4:28 AM, Alan Carter <alancarteresq(at)onetel.net> wrote:
Hi.
450 hours, !
Alan.
Dick Maddux
Posted: Mon Jan 21, 2013 5:55 am Post subject: reverse prop rotation at shut down |
Thanks for all your replies.
I have tried shutting down at high idle...that didn't work as then it really wants to go backward !
Going from a Warp to a Kiev prop,which is lighter ,helped a lot but still once in a while I get the reverse rotation if I am not judicious in low rpm shutdown.
The engine only has 350 hrs total and the timing is fixed of course. It starts and runs great. It really only has that one consistent bug at shutdown I have to watch for. Again if I shut down at around 1000-1200 rpm,it seems to do OK. I too taxi (at) 1800 rpm. Shutdown is one mag off,then the next off,then both off (per Rotax suggestion)
I will live with this occasional anomaly but am getting mighty tired of doing the valve check each time it does this and of course the one time I don't,it will suck air into the lifters !
My short final rpm in my Kitfox is around 2100 which equates to 1800 rpm on the deck. I too had to learn to adjust to this as I would float awhile in ground effect. (throttle is fully closed) but I am used to it now. I can always slip or use more flaps for more drag.
Dick Maddux
912 UL
Alan Carter
Posted: Mon Jan 21, 2013 6:28 am Post subject: Re: reverse prop rotation at shut down |
Hi Bob.
Happy new year to you.
Yes all correct,but some engines total millions of hours,I still thing the Rotax is not trouble free and could be better,
I,m no aero engine expert, but for this sort of engine which seems to start OK on snow mobiles maybe should have have something like a slip and grip clutch if there is such a thing,?
Disconnect the propeller, Start and Stop the engine without that huge propeller going round, once started slip the clutch in to engage the prop, and stop in the same way so the prop just free wheels down.
Now if some-one had designed something like this we would not have all these problems. Maybe also there is a reason this can,t be done and i,m talking out of my ass, but maybe not.?
Alan
max8992
Posted: Mon Jan 21, 2013 6:50 am Post subject: reverse prop rotation at shut down |
Alan,
I won't comment which part of your body talks here as internet doesn't
transmit odor (yet)
Basically the reducer includes a clutch but with no manual directive. Adding
one would add heavy components and additional causes of failure (like
existing on turboprops).
Max Cointe
mcointe(at)free.fr
-----Message d'origine-----
De : owner-rotaxengines-list-server(at)matronics.com
[mailto:owner-rotaxengines-list-server(at)matronics.com] De la part de Alan
Carter
Envoyé : lundi 21 janvier 2013 15:28
À : rotaxengines-list(at)matronics.com
Objet : Re: reverse prop rotation at shut down
--> <alancarteresq(at)onetel.net>
Hi Bob.
Rotax is not trouble free and could be better, I,m no aero engine expert,
thing,?
Alan
http://forums.matronics.com/viewtopic.php?p=392808#392808
Alan Carter
Posted: Mon Jan 21, 2013 7:47 am Post subject: Re: reverse prop rotation at shut down |
Hello Max.
Thousands of hours on Turbo props never had any trouble, proper jet engines log up 10s of millions of hours, in fact i have many hours on all types of light aircraft and can honestly say the Rotax seems to be among one the the most temperamental i have come across in starting and stopping. Once its going it seem to work fine. From the post on the form you must admit it is troublesome in starting, Hence the introduction of the Soft start dammage sprags ,ete ete.
Alan
BARRY CHECK 6
Posted: Mon Jan 21, 2013 8:33 am Post subject: reverse prop rotation at shut down |
Allen:
You are 100% correct. Well, at least it should run trouble free to TBO. And TBO is a certified number by the Government. Cars don't get that type of certification. Well, maybe - There is the Lemon Law.. Maybe engines should also have a Lemon Law. AFTER ALL - A plane is NOT like a car. You can't pull over at a cloud and do maintenance or request a tow truck..
One thing I have learned about Cars, Planes and People - The Cars and Planes can fail - But the People will not admit the Car, Plane, or Engine they spent good money on STINKS. They did nothing in the design or building of the engine but will swear it is the best thing since sliced bread. I have no problem about bitching about a car, plane or engine that has more bugs than a freshly burred corps in a pine box. Lycoming had huge problems until the lawyers fixed them all. My Lycoming had huge problems until it was Majored for a third time (it seams to be working - ONLY time will tell).
The two issues are:
1 - They are mechanical - They are not perfect.
2 - They are built by people - And surely you know they are not perfect.
By the way Allen, a fellow I know has 588,000+ Miles on a GMC Jimmy - GM purchased the car and dismantled the engine - They said it had about as much ware as a 12,000 mile engine. It is in some type of record book. Oh, he also ONLY used Mobile 1 Full Synthetic Oil and changed the oil ever 2,500 miles. Now That is CRAZY!
All I want is an engine to do TBO and not have to fly every second worrying about a Emergency Place to Land.
And no - I do not do that.
Barry
On Mon, Jan 21, 2013 at 5:28 AM, Alan Carter <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)> wrote:
[quote] --> RotaxEngines-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)>
Hi.
450 hours, !
Alan.
http://forums.matronics.com/viewtopic.php?p=392791#392791
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Alan Carter
Posted: Mon Jan 21, 2013 9:19 am Post subject: Re: reverse prop rotation at shut down |
Hi Barry.
Well Barry 588,000 is a long way, but i still think 330000 miles i have some sort of record,as the car was left outside all year round never, never serviced at a garage, and all i ever did was change the oil and filters every 10,000.plus the usual odds and ends like brakes.
I do get some flak on my posts ,no expert on anything,but voice my ideas for discussion, as i found out in Aerobatics there is always some-one who can do it better, so open for the input from others on the Forum,be it good or bad,
However i left myself a bit open. don,t think i will mention my anatomy again
Alan
BARRY CHECK 6
Posted: Mon Jan 21, 2013 10:51 am Post subject: reverse prop rotation at shut down |
Alan:
I do not feel you left yourself open at all. It is a positive way of thinking what SHOULD be expected from an engine, especially an aircraft engine where you put your life and those of your passengers to the test every time you fly.
Yes, 330,000 miles is quite great - And you take care of your car engine the way I do. My Hyundai has 225,095 miles as of this morning. And I change the oil twice a year whether it needs it or not
Oh, No burping required on the Hyundai either. No $8.00/Qt oil either. No $20.00 oil filter either. No $25.00/Pt of Cam Guard either. GRANTED! Our cars are used way more often than our planes and we MUST do what we can to safeguard our play-toy investment. AND you have to remember this: Our planes are used at 65% to 75% of power for 95% of the flight; 100% during takeoff. Our cars are about 20% of the HP during cruse - BIG DIFFERENCE. Some day I am going to install my spare fuel flow gauge in the car and play with the Fuel flow BHP numbers just to see what they really are.
Barry
On Mon, Jan 21, 2013 at 12:19 PM, Alan Carter <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)> wrote:
[quote]--> RotaxEngines-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)>
Hi Barry.
Alan
[Wink]
Alan Carter
Posted: Mon Jan 21, 2013 11:10 am Post subject: Re: reverse prop rotation at shut down |
Hi All.
Just to clarify on this ,Iwas told i should not compare a Rotax with a Turbo Prop, absolutely right, and i was not.
All i am saying for £25000 i expect an engine with better starting and stopping.
And these problem's are serious as they could cost you a new engine.
Alan
Dick Maddux
Posted: Tue Jan 22, 2013 6:05 am Post subject: reverse prop rotation at shut down |
Roger,
I had the gearbox disassembled and re shimmed about 65 hrs ago. It didn't make any difference at all, it still goes backward sometimes.
For what it is worth, the engine is a mid 90's 912 UL with about 350 hrsTT.
The only thing that appears to help is to pull the throttle back until the engine sounds like a "grinder' (not good on the box I am sure) around 1000 rpm and then shut it down .
The much lighter Kiev (vs Warp) really reduced these events though. The last one was my fault as I shut down about 1400 rpm.
Why hasn't it sucked air into the lifters so far ? It turns backwards at least 3 full revolutions. They told us in all my Rotax classes to never turn the prop backwards or this could happen. I have had the reverse business at least 10 times and on each occasion I have done the valve check and it never caught any air in the valves. Oil filter analysis doesn't reveal any metal either.
I do like to work on engines,airframes ,etc which is a good thing cause the Rotax has given me a lot of practice and I learn more about it. This engine is a mystery in many ways requiring research and advice from gurus such as yourself (which I thank you for !) I am sure that if I had a younger engine I would not have the problems that I do.(broken coil wires,old HD wires,spark plug caps,etc)
I am still adverse to taking my plane on a long trip though as there would be little to no support if the engine decides to act up again. We do have a guy here in Pensacola that flys his CT back and forth to the West coast and thinks nothing of it. An AI friend of mine(with my assist) help to maintain it for him and it has been very reliable.
By the way,I was able to get new NGK plug caps for $6.30 each vs the almost $50 Rotax wanted. They are the same part number. Overall I saved about $500 on my plug harness replacement and it did solve my misfire problem. The engine runs even smoother now !
Dick Maddux
Rotax 912UL
Kitfox 4
ricardourio(at)gmail.com Guest
Posted: Tue Jan 22, 2013 7:47 am Post subject: reverse prop rotation at shut down |
It´s like autoignition. Maybe a hot point inside engine can do it, like excessive carbonization, of a incomplete very rich burn, or maybe wrong spark plugs. Have you tested your magneto switch to see if it is grounding appropriately the magneto wire ?
Ricardo Urio
2013/1/22 <Catz631(at)aol.com (Catz631(at)aol.com)>
[quote] Roger,
Dick Maddux
Rotax 912UL
Kitfox 4
Dick Maddux
Posted: Wed Jan 23, 2013 6:09 am Post subject: reverse prop rotation at shut down |
Ricardo,
Thanks for your reply.
I have checked the "P" leads with an ohmmeter and they check good. A bore scope revealed nothing abnormal in the cylinders.
I let the engine idle for a minute or two prior to shutdown in order to cool any "hot spots"
Most of the time I don't have this reverse problem. It is a once in awhile thing usually related to higher engine rpm at shutdown when I am not focusing on it.
This is kind of similar to the on going problem of a friend's Paradise P-1. His engine has a vibration at cruise rpm that we can't "nail down" We have gone thru the carbs,engine mounts,airframe,rebuilt gearbox twice,changed the prop,plugs,.....etc. The "ghost in the machine" I guess.
I can live with my problem as it is controllable but that constant vibration at cruise would drive me nuts !
Dick Maddux
912 UL
Thom Riddle
Posted: Thu Jan 24, 2013 5:25 am Post subject: Re: reverse prop rotation at shut down |
Dick,
I know a guy who has been flying a Kolb Slingshot w/ 912UL for a long time. For several years he complained about what he called a "Rum Rum Rum" sound that he could never cure. Sort of like the harmonics sound you get with a twin engine recip airplane when the two engines are not quite in synch. Or tuning a guitar with a tuning fork and the guitar is not quite in tune. He did everything everyone suggested to no avail. Finally, he sent his gearbox to Lockwood (I think) and it took a changing of the gear set to rid it of that sound. My memory of the details could be off.
He may be on this Rotax List, if not, I know he is on the Kolb Matronics list. It might be worth contacting him if the "vibration at cruise" you friend is having is similar to what he had. His name is Ted Cowan.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
