Mike Whisky
Posted: Tue Jan 29, 2013 1:40 pm Post subject: torque value of fuel servo/engine studs |
Hello,
can someone please tell me what the torque value of the fuel servo/engine studs are. Or where I can find this information.
Michael
_________________ RV-10 builder (flying)
#511 |
flying-nut(at)cfl.rr.com Guest
Posted: Tue Jan 29, 2013 2:06 pm Post subject: torque value of fuel servo/engine studs |
AC 43-13 is the 'bible' for aviation and everybody should have a copy. You'll have far more knowledge at your fingertips ...... or mouse ..... than you'll possibly have questions for!!!
You can find it here: http://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/document.information/documentID/99861
or http://tinyurl.com/3hr4js4.
To answer your question .... at least generally, look at table 7-1 0n page 7-9 of AC43-13 for torque values for various size bolts.
Linn
On 1/29/2013 4:40 PM, Mike Whisky wrote:
[quote] [b]
charliewaffles
Posted: Tue Jan 29, 2013 2:36 pm Post subject: Re: torque value of fuel servo/engine studs |
Actually, when it comes to the engine side of things, Lycoming specifies the torque for everything on the engine. You should refer to Service Table of Limits - SSP_1776 for anything relating to the Lycoming studs, bolts, nuts, etc... If its not called out for specifically, they have a default torque section at the end of the document. These are typically HIGHER than anything in AC43.13 or other sources as most threads are coarse threads.
Kellym
Posted: Tue Jan 29, 2013 4:36 pm Post subject: torque value of fuel servo/engine studs |
True, but with the servo, higher torque values are not better. You only
need enough to secure it and the gasket from air leaks. Very different
than holding case parting line together, for example. Also, you will be
using a lock tab, so they are not going to loosen. I'd recommend
sticking with the AC43-13-1B values for this application.
Just as Lycoming's spark plug torque value is 10 ft lbs higher than
Continental's, for the very same threads in the same helicoil and same
aluminum alloy. The Lyc representatives I've talked to could never give
a reason for the high torque value for spark plugs, that just about
requires a breaker bar to remove them. I've been using 25 ft lbs on my
certified Lycoming for over 10 yrs and 700 hours with no issues.
Kelly
A&P/IA
On 1/29/2013 3:36 PM, charliewaffles wrote:
http://forums.matronics.com/viewtopic.php?p=393246#393246
Checked by AVG - www.avg.com
KCHD |
