crabandy(at)yahoo.com Guest
Posted: Thu Feb 14, 2013 11:14 am Post subject: Diagram Z-13 |
Reference Diagram Z-13 from the main power distribution bus the alt field wire shows a fusable link followed by a circuit breaker then the switch. Is it an option either fusable link or circuit breaker?
Could you also just use a fuse in the fuse holder, it just introduces "gremlins" the fuse holder could be loose or corrode ?
Andy
Posted: Thu Feb 14, 2013 11:26 am Post subject: Diagram Z-13 |
At 01:12 PM 2/14/2013, you wrote:
Are your busses tapped with circuit breakers or fuses?
z-13 illustrates the use of fuse blocks. The crowbar
ovm systems require a panel mounted breaker. Hence, the
BUS is EXTENDED from the fuse block to the breaker;
the extension is protected with a very robust fuse
or 'fusible link'.
If you're building with breakers, then the fusible
link is not necessary.
| Quote: | Could you also just use a fuse in the fuse holder, it just
Look up Fusible Link on the website. This
is a special kind of fuse used in limited
and unique situations.
Posted: Thu Feb 14, 2013 12:33 pm Post subject: Diagram Z-13 |
I am wired with the auto fuse blocks, i understand the fuseable link concept, i think. I'm having trouble understanding why the crowbar OVM requires the circuit breaker instead of using an auto fuse.
Thanks again for all your shared info,
Andy
On Feb 14, 2013, at 1:26 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
or 'fusible link'.
longg(at)pjm.com Guest
Posted: Thu Feb 14, 2013 1:02 pm Post subject: Diagram Z-13 |
Andy,
With CBs and Airplanes you get 1 chance to reset. This gives you that 1 chance. If it pops again, never reset it until you are on the ground. Last time I tried to change a fuse while flying my wife kept yelling something like, "we gonna die"
The fuse-able link allows that link (the smaller wire) to break the circuit if the main wire ever gets hot enough to burn back to the bus. I tested that 1 on the ground. It works The link wire needs to be large enough to handle the expected load + 20% or so.
My rationale for fuses is pretty simple. If you need it to land safely, don't use a fuse. In my bird there is very little that I can claim to be absolutely necessary for landing (without getting hurt). Flaps are 1 of them.
I'll never have to worry about getting published in IEEE, but I've discovered what works practically over time. The two are often different.
Glenn
Posted: Thu Feb 14, 2013 2:33 pm Post subject: Diagram Z-13 |
Thanks for the replies. It is referenced several places in the connection that the crowbar over voltage needs a circuit breaker. Does the crowbar over voltage not work with a fuse? Why?
Thanks again!
Andy
On Feb 14, 2013, at 3:01 PM, <longg(at)pjm.com> wrote:
Andy,
Glenn
Posted: Thu Feb 14, 2013 4:00 pm Post subject: Diagram Z-13 |
At 02:31 PM 2/14/2013, you wrote:
Because it MAY nuisance trip and you want to
be able to reset it from the pilot's seat.
Posted: Thu Feb 14, 2013 6:24 pm Post subject: Diagram Z-13 |
Roger!
Thanks again,
Andy
On Feb 14, 2013, at 6:00 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
