snaps(at)embarqmail.com Guest
Posted: Tue Mar 05, 2013 2:17 pm Post subject: Kitfox-List Digest: 3 Msgs - 03/02/13 |
I m flying with warp r=drive props for 32 yrs and never heard for drilling
props and hubs.
Just got off phone with Darryl, 800 833 9357, he wants to hear from you!!!
and any body else with a problem.
One of the BEST companies to deal with!!!
john" snaps "knapp
lcfitt(at)sbcglobal.net Guest
Posted: Tue Mar 05, 2013 5:46 pm Post subject: Kitfox-List Digest: 3 Msgs - 03/02/13 |
Thanks John, for the note and for checking up on the subject. I will call
tomorrow. I flew 900 hours with my old Warp Prop, but this one would not
hold pitch on one blade - only 40 hours. It was the one with the decal on
it so it was easy to find. I got the pinning advice from the factory -
don't recall who I talked to.
Lowell
Sent: Tuesday, March 05, 2013 2:15 PM
Subject: Re: Kitfox-List Digest: 3 Msgs - 03/02/13
props and hubs.
john" snaps "knapp
Posted: Wed Mar 06, 2013 2:48 pm Post subject: Kitfox-List Digest: 3 Msgs - 03/02/13 |
I just got off the phone with Darryl at Warp Drive, and I guess my first
explanation was not very clear -
"I drilled two 3/16" holes through the collar and into the hub about 3/8"
deep. and about an inch from the hub end. I cut two pins of 3/16" aluminum
and glued them in the holes with a structural adhesive. I have to say here
that this is what I did as I forgot to ask him for the factory recommended
procedure. If anyone else is having this problem, I would suggest calling
for the exact recommendations."
To clarify when I mentioned "hub" what I meant to say is the root end of the
blade. I made no alterations to the Aluminum hub halves. Also when I
re-read my original explanation, I don't know how it came to read two holes
and two pins as I only used one. Warp suggests that a 1/8" pin would be
sufficient.
Thanks for the observation.
Lowell
props and hubs.
john" snaps "knapp
