henrysfork1(at)msn.com Guest
Posted: Thu Mar 07, 2013 6:48 pm Post subject: Program |
There used to be a weight and balance program foating around out there. I used it for my model 2 on the original build. Any ideas where I might find it?
Dee
Model ll
KFM 112
N345DY
Sent from Samsung tabletdholly <oue191(at)yahoo.com> wrote:
In a similar forum discussion, John McBean offered this reply:
How to Cure a Heavy Wing
Re: Trying to correct left roll in cruise flight.
You are entering the "Test Pilot" stage. Be sure you are qualified and comfortable with making changes and test flying your aircraft.
Knowing that you are not the builder... I would suggest a reset... assume nothing.
Check the horizontal stabilizer for correct installation..
Set the wings back to the standard known condition and start from there.
Refer to your manual. 1 degree twist and 1 degree dihedral. Check length of the rod end thread.
| Quote: | From that point you can adjust either side.. we will typically decrease the angle of incidence first then increase on the opposite wing if needed. try to make changes equal.
For example.. We have a slight left turn.. or a heavy left wing as they say
MDKitfox(at)aol.com Guest
Posted: Thu Mar 07, 2013 7:05 pm Post subject: Program |
Dee,
I have an Excel spreadsheet for a Model 5 if you think that would help.
Also, there's an EAA webinar scheduled for the near future on weight and balance if you want to learn more on that subject.
Rick Weiss
Series V (Skystar s/n 1) Speedster:-)
Rotax 912S, Dynon Sky View
Spruce Creek Fly-In, FL
MDKitfox(at)aol.com (MDKitfox(at)aol.com)
On Mar 7, 2013, at 9:44 PM, henrysfork1 wrote:
| Quote: | There used to be a weight and balance program foating around out there. I used it for my model 2 on the original build. Any ideas where I might find it?
Dee
Model ll
KFM 112
N345DY
dholly <oue191(at)yahoo.com (oue191(at)yahoo.com)> wrote:
--> Kitfox-List message posted by: "dholly" <oue191(at)yahoo.com (oue191(at)yahoo.com)>
For example.. We have a slight left turn.. or a heavy left wing as they say.
We have determined that we do not have a yaw issue that is causing the left turn.
We adjust the right wing rear lift strut rod end out 1 turn... record our change and pre-flight for a test flight. Decreased Twist (wash-out)
Not enough.. so now we'll adjust the left wing rear lift strut rod end in one turn.. record our change and pre-flight for a test flight. Increased Twist (wash-out)
Still not enough.. adjust the right wing front lift strut rod end in 1 turn... record our change and pre-flight for a test flight. Decreased Twist (wash-out)
Still not enough.. adjust the left wing front lift strut rod end out 1 turn... record our change and pre-flight for a test flight. Increased Twist (wash-out)
You may need to make a 1/2 turn or maybe a 1 1/2 turn all depends on the severity of the roll rate...
__________________
John McBean
www.kitfoxaircraft.com
208.337.5111
-Kitfox III 582 Blue/C Grove Spring / Aerocet 1100 Amphibs
-Airdale Avid+ (project) TD / W.I.B. Gear
http://forums.matronics.com/viewtopic.php?p=395688#395688
; - The Kitfox-List Email Forum -
r?Kitfox-List">http://www.matronics.com/Navigator?Kitfox-List
; - MATRONICS WEB FORUMS -
; - List Contribution Web Site -
; -Matt Dralle, List Admin.
tion">http://www.matronics.com/contribution
steve.didier(at)gmail.com Guest
Posted: Thu Mar 07, 2013 7:21 pm Post subject: Program |
On 03/07/2013 07:04 PM, Richard Weiss wrote:
| Quote: | Dee,
Rick Weiss
Dee
Model ll
KFM 112
N345DY
__________________
John McBean
208.337.5111
Here you go off the Kitfox aircraft website!
Steve D
http://kitfoxaircraft.com/Weight%20&%20Balance.htm
MichaelGibbs(at)cox.net Guest
Posted: Thu Mar 07, 2013 10:48 pm Post subject: Program |
Murle Williams has one on his web site:
http://murlewilliamsaviation.com/downloads.html
Mike G.
Phoenix, AZ
Kitfox IV-1200 Speedster/Kitfox Series 6
