dfritz(at)bpgsim.com Guest
Posted: Mon Mar 11, 2013 10:08 am Post subject: Finishing Kit Substitution Costs |
I pretty much went with the list of substitutions suggested on Tim's
site and this list. My windshield and back side windows came with the
fuselage kit I already had. I chose to delete the two door windows for
which Van's credited me $110 each. The door windows from Dresser cost
$150 each. Van's credited me $100.38 for the nose wheel. MATCO charged
130.49 for the nose wheel. Van's credited me $68 each for the main gear
tires and $52.40 for the nose wheel tire. Dresser charge $69 each for
the main gear retreads and $69.95 for the nose wheel retread. Thus
these were not direct cost substitutes, but the nose wheel is a must and
I hope the windows are worth the difference and I understand the tires
wear longer. I thought this might be of interest to those at this stage
of the build.
Dave
Dave Fritzsche
40813
Puyallup, WA
Fuselage
rv10flyer(at)live.com Guest
Posted: Mon Mar 11, 2013 10:30 am Post subject: Finishing Kit Substitution Costs |
Dave;
I helped Desser with the front window/windscreen another builder with the
sides- they fit perfectly versus having to do all the trimming to make it
fit. The quality of Cee baileys is also better than that sent from Vans.
Keep in mind that you may pay more for the windows, Matco and tires but you
are far better off for it. In the end you really saved a whole lot of time
and eventually money as the parts you replaced from the Vans parts will last
far longer.
I make nothing on this, but believe me I worked with Desser/Cee Baileys
because the windows are lacking from Vans and the product Desser came up
with was based on thriving for perfection and a perfect fit "as is". Until
you have put the windows on and off 20 times to get the gap right one would
not understand the advantage of having a nearly perfect fitting piece on
arrival. I tossed my windscreen as I had a "bulge" on the co-pilot side and
used the Desser version that was rounded and tight fitting throughout.
Thanks for the feedback!
Pascal
Posted: Tue Mar 12, 2013 1:47 pm Post subject: Finishing Kit Substitution Costs |
I received a couple e-mails asking for more information on the parts the
Desser replace. I am pretty certain Tim has this already somewhere on his
website however for easy reference.
I broke down the Desser/Cee Bailey's packages and the respective Vans part
number it replaces. Keep in mind that I recall the windows came with a
earlier kit than the finish kit. Best to have Vans send a copy of the parts
list at each point and review to see if any of the parts that are being
replaced are removed.
Desser site:
Wingtip position light lenses- VA193
http://www.vansaircrafttires.com/products/RV%252d10-Clear-Wing-tip-lenses-%28pair%29.html
Complete Windows kit -
http://www.vansaircrafttires.com/products/Cee-Bailey%27s-RV%252d10-Windshield%2C-pilot-%26-co%252dpilot-door-windows%2C-left-and-right-rear-window-set.html
Individual kits:
Side rear windows- C-1004L/C1004R
http://www.vansaircrafttires.com/products/RV%252d10-Rear-%28Left-or-Right%29-Window.html
side DOOR windows C1003L/1003R
http://www.vansaircrafttires.com/products/RV%252d10-pilot-%26-co%252dpilot-door-windows%2C-left-and-right-rear-window-set.html
front windscreen (C-1005)
http://www.vansaircrafttires.com/products/Cee-Baileys-RV%252d10-Windshield.html
tires
http://www.vansaircrafttires.com/products/RV%252d10-New-Builders-Special-save-10%25-%28two-15%7B47%7D600%252d6PR-Retreads%2C-two-Aero-Classic-Easy-Flate-Tubes%2C-one-5.00%252d5-6PR-Elite-Retreads%2C-and-one-Aero-Classic-5.00%252d5-Butyl-Tube%29.html
The advantage of getting the retreads now, if one is ever going to go this
route, is that the wheel pants are spaced correctly around the tires when
building, otherwise one may find they need to make the area larger after
replacing the stock tires with retread.
Hope this helps!
Pascal
