Kellym
Joined: 10 Jan 2006 Posts: 1705 Location: Sun Lakes AZ
Posted: Fri May 31, 2013 7:22 pm Post subject: Floscan location and Matronics fuel line pulsation damper |
I have Skyview Revision N Install manual. I see nothing in that manual
saying the sensor should not go forward of the firewall. The EI Red Cube
(current Dynon sensor) is installed on many certified aircraft. For
Lycoming engines with Bendix fuel injection, the STC required location
is between the mechanical pump and the fuel servo inlet, away from
exhaust pipes. I have one in that location on my Mooney.
The tunnel has known problems, more likely from the fact it is on the
suction side of the mechanical pump than from heat.
On 5/31/2013 7:58 PM, Pascal wrote:
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=99641917?KEYS=pulsation_damper?LISTNAME=RV10?HITNUMBER=1?SERIAL=1955173315?SHOWBUTTONS=YES
Have mine in the tunnel. I had a low fuel pressure warning twice- it
was 0ver 85F on a climb, otherwise never had any issue with it's
accuracy.
Many will tell you to move it to the firewall, Dynon, for one, tells
the installers not to, and all I can think is that it would be even
hotter there than in the tunnel.
KCHD |
Posted: Fri May 31, 2013 11:16 pm Post subject: Floscan location and Matronics fuel line pulsation damper |
The beauty of putting the cube in the tunnel is that you get to remove & relocate it once you are flying. Talk about enjoyable! I did as the plans describe and had 2-3 gph fluctuations including 800 RPM taxi showing 12 GPH... sometimes. Other times it would read 4.3 GPH. Want another indication just flip on your boost pump and you get a whole different reading. No way for me to balance injectors w/o accurate fuel flow. I relocated FWF (I like Sean's install in archives) and all issues went away. I still get the occasional 0.4 GPH fluctuations but that is because I don't have the ideal length flow in/out of the cube.
I only have read one pirep on the damper and it was No Joy.
Robin
aerosport1
Posted: Sat Jun 01, 2013 6:23 am Post subject: Floscan location and Matronics fuel line pulsation damper |
I ditto Robins remarks. Why take the chance of having a problem and then have to move it. PIREP from everyone
Having it FWF is positive. 400 hrs and
Great results for myself. Soft mount it up front and be a happy.
Geoff
Robin
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
arplnplt(at)gmail.com Guest
Posted: Sat Jun 01, 2013 8:03 am Post subject: Floscan location and Matronics fuel line pulsation damper |
Definitely put it between the servo and spider.
I talked directly with Flo-Scan about this and they said the worst place is between the the two fuel pumps. They said the best would be before the valve. (We can't do this obviously.)
I installed mine just in front of the servo (or after as flow goes,) with a somewhat floating, flexible mount on the air box. I'm within a 1/2 gallon on every fill.
Use flexible hose, do not make it rigid.
Dave Leikam
N89DA
Geoff
> Robin
Posted: Sat Jun 01, 2013 8:29 am Post subject: Floscan location and Matronics fuel line pulsation damper |
I mounted my Dynon "red cube" in the tunnel. I knew some had issues with
this location but it was the easy option. I do see some minor flow
fluctuation when I turn on the boost pump. Overall operation however is
fine and rock steady. My fuel used total is always within half a gallon
when I fill up. At this point I have no reason to move it. If I had it to
do over however I'd would likely put the cube between the throttle body and
the spider like I did in the 8A.
I did insulate the tunnel at the firewall and the tunnel floor, and I put a
piece of insulation between the red cube and the tunnel mount. I don't have
any tunnel heat issues.
Carl
90 hours.
rv10flyer(at)live.com Guest
Posted: Sat Jun 01, 2013 8:46 am Post subject: Floscan location and Matronics fuel line pulsation damper |
The flip side is Dynon does tell one (pg7-41) "It is common to place the
sender downstream of any auxiliary electric boost pumps but upstream of the
engine driven fuel pump." as does Vans. I think they need to consult Floscan
on getting that perception updated!! I am usually less than .3 off at
fillups, could be user error as well since I say 60 gallons and there may be
59.X, but it is pretty consistent and minor.
My point is that it works just fine for me in the tunnel. It probably is
easier to install in the spider/ servo area as the tunnel setup was a bear
for me from the boost pump, but it works and I don’t see a need to move it..
With all that said- If I was doing this again- I would seriously consider
putting it up front by the servo/spider.
Kellym
Posted: Sun Jun 02, 2013 12:40 pm Post subject: Floscan location and Matronics fuel line pulsation damper |
Your transducer is after that loop regardless of whether it is in the
tunnel or on the engine. Has no effect on measurement going through the
transducer.
The loop simply allows the pump output to be held to a preset maximum,
with any excess going back to the pump inlet.
On 6/2/2013 10:01 AM, ibspud(at)roadrunner.com wrote:
Quote: | I was referring to the return loop on the Airflow Performance pumps that goes from the pump manifold back to a T fitting at the fuel selector valve input. My calculated fuel consumption agrees closely with actual consumption so it appears there is little recirculated fuel involved. Just wondering what the return loop's function is?
Albert Gardner
N991RV
Yuma, AZ
---- Kelly McMullen <kellym(at)aviating.com> wrote:
> It is an unusual installation for a Lycoming fuel injected engine to
> have a fuel return line. Bendix FI does not. AF has a purge line which
> may or may not return to the tank, but is only used for shutdown, there
> is no return when engine is running. Only Continental injection or
> systems modeled after it have an active return line, and there are
> sensors to account for that fuel, but not something that most RV-10
> operations need to be concerned with.
> On 6/1/2013 9:56 PM, ibspud(at)roadrunner.com wrote:
>> Since, on injected engines, there is a fuel return line that goes from the pump back to the fuel selector valve, does the Floscan sender report higher flue flow than is actually used by the engine? Or is there only a small amount of fuel returned via that bypass route?
>> Albert Gardner
>> N991RV
>> Yuma, AZ
> No virus found in this message.
> Checked by AVG - www.avg.com
KCHD |
rv10flyer
Posted: Mon Jun 03, 2013 9:31 pm Post subject: Re: Floscan location and Matronics fuel line pulsation damp |
My red cube works fine in the tunnel. With the boost pump on, fuel line disconnected at servo inlet, I was getting 42 gph flow. Plenty for an engine that needs 26-27 gph at takeoff. I made a 5052 tube to take the place of my red cube/two hard lines if I ever need to move it. Same as others...accurate to .5 gallon.
_________________ Wayne G. |
