Don Pfeiffer
Joined: 10 Nov 2010 Posts: 3 Location: Poplar Grove airport
Posted: Thu Jun 13, 2013 3:19 am Post subject: Slickstart and electronic tachs |
Anybody who installed a slickstart and also has a electronic tach (which probably is everybody.)The installation instructions for the SLICKSTART wants it wired thru the left mag and comments that any electronics tachs should therefore be wired thru the RIGHT mag. The problem is that my ELECTRONICS INT"l tach instructions has me wiring to both P leads both left and right. Anyone experience this? Don Pfeiffer
Bajajim
Posted: Thu Jun 13, 2013 9:43 am Post subject: Slickstart and electronic tachs |
Don,
I tried the "P lead" hookup without much success.
I ended up going with a "Signal Generator" from Aircraft Spruce.
Screws on your existing tach drive and a simple 2 wire hookup.
Solves a lot of headaches..
Readout is plus or minus 3 rpm...
About $70.00
http://www.aircraftspruce.com/catalog/inpages/adirh60-sg.php0.00
Jim Villani
N10KQ
100 plus hours
rv10flyer
Posted: Thu Jun 13, 2013 7:13 pm Post subject: Re: Slickstart and electronic tachs |
I have GRT EFIS and slick start. I installed resistors in both circuits then into a spdt switch then to GRT EIS. Works great on either mag position.
_________________ Wayne G. |
Bob Turner
Posted: Thu Jun 13, 2013 7:27 pm Post subject: Re: Slickstart and electronic tachs |
I have exactly the same as Wayne except I skipped the switch and wired them both into the GRT EIS. The EIS automatically shows whatever is wired to #1 unless it's zero (as during mag check) in which case it goes to #2 (and shows "#1 RPM failed" message or something like that.
_________________ Bob Turner
RV-10 QB |
Posted: Mon Jun 17, 2013 4:19 am Post subject: Slickstart and electronic tachs |
I went with the solution that puts a sensor into one of the two mags. I
forget the details.... and whether it operates when the mag is switched off.
Why? Because I no longer look for a mag drop as a mag check. Rather,
with a GRT EFIS and EIS I watch EGTs during the mag check. When one is
switched off, all EGTs should rise. If there is a problem with a plug
or a cylinder, that EGT won't rise.
