jeepacro(at)cox.net Guest
Posted: Sun Jun 11, 2006 8:45 pm Post subject: paint |
learning poly-tak will melt zink chromate I was wondering can I basically spray on any (epoxy) paint I wont to and still be OK when I put the poly -tak on it? I was told anything epoxy is OK with poly-tak, is this true? Thank in advance.............Rob.
Richard Pike
Posted: Sun Jun 11, 2006 9:22 pm Post subject: paint |
I have never been to crazy about spraying epoxy, it is pretty toxic.
However, you can brush it on and it is very easy to sand. I have brushed
epoxy on several fuselages and then gone over it with some 220 sandpaper
with good results. Since you will want to sand it a bit anyway to make
the Poly Tak stick well, why not? Poly Tak sticks to sanded epoxy real
well, with no adverse effects. If there is something of dissimilar
metals so you think you need zinc chromate between the metals, do it,
and then put epoxy over the zinc chromate, and then the Poly Tak. It
will last longer than you will.
Richard Pike
MKIII N420P (420ldPoops)
jeepacro(at)cox.net wrote:
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
FS2Kolb(at)aol.com Guest
Posted: Mon Jun 12, 2006 7:31 pm Post subject: paint |
In a message dated 6/11/2006 10:46:19 P.M. Mountain Daylight Time, jeepacro(at)cox.net writes:
| Quote: | | learning poly-tak will melt zink chromate I was wondering can I basically spray on any (epoxy) paint I wont to and still be OK when I put the poly -tak on it? I was told anything epoxy is OK with poly-tak, is this true? Thank in advance.............Rob. |
Rob,
Check out Aircraft Technical Support
or call them toll free at 1-877-877-3334 and they will be able to help you.
