brunk
Joined: 08 Jan 2013 Posts: 25 Location: Corpus Christi, texas
Posted: Mon Jun 24, 2013 6:18 am Post subject: lightspeed ignition troubleshooting |
On Jun 24, 2013, at 9:16 AM, Robert Brunkenhoefer <robert(at)brunklaw.com> wrote:
| Quote: | I have been trying to troubleshoot a drop of 250 rpm on run up on my light speed side. I usually get 0 drop. I also show a 250 degree rise above the other cylinders in the 3 and 4 egt. Cht is normal for all. I have done all the troubleshooting in the manual supplied by Klaus. We have spoken a lot about this problem. I would like to fly my plane somewhere nearby to someone who is familiar withs these units so I can get back to the perfect way it was for 5000 plus hours. thanks. I am based at KCRP, corpus christi , texas. Robert Brunkenhoefer N661G 600 hours plus
_________________ Robert E. Brunkenhoefer |
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Mon Jun 24, 2013 6:34 am Post subject: lightspeed ignition troubleshooting |
So when you take the coil-to-plug leads off and you pull the prop
through, you're getting the spark jumping across the leads on the coil,
right? And at the right time?
On 6/24/2013 9:17 AM, Robert Brunkenhoefer wrote:
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
brunk
Posted: Mon Jun 24, 2013 6:39 am Post subject: Re: lightspeed ignition troubleshooting |
Yes, that is correct. spark plug leads were replaced and coil to 3 and 4 was replaced, as well as all spark plugs. connections were checked on both ends of the system.
dave.saylor.aircrafters(a Guest
Posted: Mon Jun 24, 2013 6:40 am Post subject: lightspeed ignition troubleshooting |
I've found LS to be pretty sensitive to dirty plugs. It's early on the troubleshooting checklist but even of they looked ok you might try a new set. I just had that work for me under similar circumstances. In my case the plugs were only 3 hours old and just looked a little used but not bad at all. New plugs did the trick.
On Monday, June 24, 2013, Robert Brunkenhoefer wrote:
| Quote: | --> RV-List message posted by: Robert Brunkenhoefer <[url=javascript:;]robertbrunk(at)mac.com[/url]>
On Jun 24, 2013, at 9:16 AM, Robert Brunkenhoefer <[url=javascript:;]robert(at)brunklaw.com[/url]> wrote:
target="_blank">http://www.matronics.com/Navigator?RV-List
MS -
e -
Dave Saylor
831-750-0284 CL
rv8a2001(at)yahoo.com Guest
Posted: Mon Jun 24, 2013 7:42 am Post subject: lightspeed ignition troubleshooting |
Do you have the old RG-58 coax cable to the coils? This caused me trouble, replaced it with RG-400 cable problem solved.
Scott
To: rv-list(at)matronics.com
Sent: Monday, June 24, 2013 7:39 AM
Subject: Re: lightspeed ignition troubleshooting
--> RV-List message posted by: "brunk" <robertbrunk(at)mac.com (robertbrunk(at)mac.com)>
http://forums.matronics.c; -Matt Dral=============
brunk
Posted: Mon Jun 24, 2013 7:43 am Post subject: Re: lightspeed ignition troubleshooting |
Dave, I replaced the plugs with new ones and experienced no change from that.
brunk
Posted: Mon Jun 24, 2013 10:49 am Post subject: Re: lightspeed ignition troubleshooting |
This is the original coax cable . I do not know the number of it. Would it cause the symptoms I described? Was that your problem it corrected?
Bob Collins
Posted: Mon Jun 24, 2013 11:11 am Post subject: lightspeed ignition troubleshooting |
If you're getting a spark jumping across the leads, I doubt it's the
coax. You've changed the spark plugs (and the copper washers, right?)
and if you're EGT is going up , those plugs aren't firing. The next
thing I would eliminate as a possible cause are the wires from the
coil(s) to the individual plugs. Assuming you've doublechecked to be
sure these didn't somehow get routed to the wrong plugs (ask me how
know), try swapping the wires, disconnecting them from the coils and
plugs and connecting them to another (appropriate) coil and another
(appropriate) plug and see if that same plug doesn't fire or if another
plug becomes the one that doesn't fire.
Assuming nothing changes, I think you've eliminated the Lightspeed as
the cause and we can start just diagnosing the only three things it can
be from there forward : spark, fuel, or air, and we might be able to
eliminate spark.
St. Paul, Minn.
Posted: Mon Jun 24, 2013 3:04 pm Post subject: lightspeed ignition troubleshooting |
The RG 58 is black.
I had a strange intermittent miss when turning off one ignition. One thing to remember is RG 58 was designed for WWII aircraft. RG 400 is MODERN! RG 58 is NOT designed to handle under cowl temps. Especially the center conductor insulation.
vshimsl(at)live.com Guest
Posted: Mon Jun 24, 2013 3:16 pm Post subject: LightSpeed ignition troubleshooting |
Hi,
250 RPM drop compared to what read by what at what RPM setting? Run up
implies 17 to 18 hundred rpm. Are you using the digital or analog rpm signal
from the LightSpeed? CHT temps should drop, at least they do for me, when a
cylinder is not firing. But yours are 'normal'. Do you hear/feel the RPM
drop or is your only indication an instrument RPM reading drop? Your
tachometer could be missing pulses (if digital) from the LIghtSpeed, and
your tachometer is a...?
VinceH
RV8 Flying
hours plus
