BobbyPaulk(at)comcast.net Guest
Posted: Fri Jun 28, 2013 12:08 pm Post subject: Datum Line |
p { margin: 0; }Guys,
Can anyone verify what station on the wings to drop a plumb line to get the proper Datum line.
My information says it is the fourth nose rib or the one just outside the fuel tank ( 15 gal. ).
I now hear that we should add 20mm outboard of this rib.
I am helping a friend get his ready to weigh and would like to know. I used the fourth rib and have not had any problems.
Is there a place on the Zenith website that would show the latest info?
The distance from my right wheel to the datum is 26.016" The left is about 5/16" less. Is this close to what most are getting?
Thank you for your help
Bobby ( age 75 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 285 Needle Jet
Status - Flying 181 hrs.
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
jaybannist(at)cs.com Guest
Posted: Fri Jun 28, 2013 12:58 pm Post subject: Datum Line |
Bobby,
There is no "proper datum line." The datum can be anywhere you want it. Most find it convenient to locate it at the leading edge of the wing. I chose to locate my datum line at the leading edge of the wing, adjacent to the fuselage, taking the forward sweep of the wing out of the picture. I suppose locating it further out on the wing could make it easier to draw on the floor.
Both my main gear wheels were the same distance from the datum.
Jay
larrycmcfarland(at)gmail. Guest
Posted: Fri Jun 28, 2013 1:03 pm Post subject: Datum Line |
HI Bobby,
You can use any point you wish for a Datum line, so long as you’re consistent with it.
The sum of the moments divided by total weight will locate a CG for any object.
Zenith would have you loading the CG limits to the design they established though.
Larry McFarland (age 73)
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of BobbyPaulk(at)comcast.net
Sent: Friday, June 28, 2013 3:08 PM
Subject: Datum Line
Guys,
Bobby ( age 75 )
Zodiac 601 XL "B"
Quote: | http://www.matronics.com/Navigator?Zenith601-List | 01234567
mhubel
Posted: Fri Jun 28, 2013 6:05 pm Post subject: Datum Line |
Bobby,
As pointed out, to use Zenith's recommended CG limits (which you really should) you do have to start with their datum point. I believe the good news is that the CH601 leading edge is basically perpendicular to the centerline (at least the CH601XL is) so the exact spot is not too critical, I can't see that +/- 20 mm along the leading edge makes any measurable difference.
On 06/28/2013 5:03 PM, Larry McFarland wrote:
Quote: | <![endif]--> <![endif]-->
HI Bobby,
From: owner-zenith601-list-server(at)matronics.com (owner-zenith601-list-server(at)matronics.com) [mailto:owner-zenith601-list-server(at)matronics.com (owner-zenith601-list-server(at)matronics.com)] On Behalf Of BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)
To: zenith601-list(at)matronics.com (zenith601-list(at)matronics.com)
Subject: Datum Line
Guys,
Bobby ( age 75 )
Zodiac 601 XL "B"
8 | 9 [quote][b]
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
paulrod36(at)msn.com Guest
Posted: Wed Jul 10, 2013 11:41 am Post subject: Datum Line |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Maybe I just missed it, but does anybody know if there's a separate worksheet for taildraggers?
Paul Rodriguez
