william(at)gbta.net Guest
Posted: Thu Feb 07, 2013 8:46 am Post subject: alodine |
A while back I recall a thread about alodine and where to get it. This particular post I remember was about a powder form. I've searched aircraft spruce and cannot find a powder form of alodine. Can anybody tell me where I might find it? Also, Ive never done the alodine before. What prep is required of the parts before using the alodine?
Bill
Ed Godfrey
Posted: Thu Feb 07, 2013 9:17 am Post subject: alodine |
Bill,
Here is a snippet of a message from Matronics RV10 list that I had a copy of.
Ed Godfrey
40717
Look up PreKote.
Ed Godfrey
Bill,
Here is a snippet of a message from RV10 list that I had a copy of.
Ed Godfrey
40717
Look up PreKote.
flying-nut(at)cfl.rr.com Guest
Posted: Thu Feb 07, 2013 9:24 am Post subject: alodine |
You can use the search engines to find a supplier near you. You might also get a local plating shop to get the powder for you. The liquid alodine is not very concentrated. As for prep, all it needs to be is squeaky clean.
Linn
On 2/7/2013 11:45 AM, Billy Britton wrote:
[quote] A while back I recall a thread about alodine and where to get it. This particular post I remember was about a powder form. I've searched aircraft spruce and cannot find a powder form of alodine. Can anybody tell me where I might find it? Also, Ive never done the alodine before. What prep is required of the parts before using the alodine?
Bill
Checked by AVG - www.avg.com
02/07/13 [b]
rleffler
Posted: Thu Feb 07, 2013 10:14 am Post subject: alodine |
I may have some powder left over, but I'll have to check on the quantity.
On Feb 7, 2013, at 11:45 AM, "Billy Britton" <william(at)gbta.net (william(at)gbta.net)> wrote:
Bill
_________________ Bob Leffler
N410BL - Phase I
Posted: Thu Feb 07, 2013 10:39 am Post subject: alodine |
If anybody has any left over I'd be willing to buy it from you. I've been on the 'net for the last two hours looking for suppliers and made several calls and nobody seems to handle it anymore. Ive called PPG - Eldorado Chemical and they dont sell to individuals so I was put into contact with Graco Supply who is a retailer for PPG. They dont have it in stock so theyre getting me info for a bid but they dont kinow minumum purchase requirements. Doesn't sound like its gonna pan out.
If anybody has any left I can purchase you can leave a message on here or preferably email me at billbritton73(at)yahoo.com (billbritton73(at)yahoo.com).
Bill
jeff(at)westcottpress.com Guest
Posted: Thu Feb 07, 2013 12:08 pm Post subject: alodine |
why don't you skip the alodine and use Prekote?
Jeff Carpenter
40304
On Feb 7, 2013, at 10:39 AM, Billy Britton wrote:
[quote] If anybody has any left over I'd be willing to buy it from you. I've been on the 'net for the last two hours looking for suppliers and made several calls and nobody seems to handle it anymore. Ive called PPG - Eldorado Chemical and they dont sell to individuals so I was put into contact with Graco Supply who is a retailer for PPG. They dont have it in stock so theyre getting me info for a bid but they dont kinow minumum purchase requirements. Doesn't sound like its gonna pan out.
Bill
rv10free2fly(at)yahoo.com Guest
Posted: Thu Feb 07, 2013 12:43 pm Post subject: alodine |
Bill,
I keep the alodine solution in a 20 litre container and top up the crystal concentration when I notice the dip time is starting to get longer to achieve the same level of coating.
I always prepare the parts by scrubbing them with a maroon 3M Scotchbrite pad in a solution of 'Deoxidine' (a Henkel product), just scrub enough to get the shine off the aluminium, then fresh water rinse and air dry before dipping in the alodine solution.
I use a storage water heater overflow tray, which is about 1.5" deep & about 4' in diameter to dip the large parts. The advantage of this tray is that it has a plastic ball valve plumbed into the tray and allows me to easily decant the solution back into the storage container for reuse. I use black plastic irrigation fittings and pipe which attach to the ball valve. Can send you pictures.
For longer, slender parts, I've made up a long bath using 6" diameter PVC sewer pipe with caps each end and another plastic ball valve fitted as described above.
I've cut the top 2" off the entire length of the pipe to allow you to sit the pipe horizontally on an old pallet. Great for long parts and gives a solution depth of about 4".
Please ensure that you read the Material Safety Data Sheet for the alodine more so, as its toxic stuff.
I've seen guys also use wheelie bins as dip baths and lowering parts in with tie wire and suspending them from some dowel placed across the bin opening. Doing this means you'll need a lot of solution and the bin is very heavy to move. I get away with 20 litres, which is stored when not required.
Yell out if you need any more info. Google the Henkel site for technical advice.
Warm regards from Oz.
Patrick
Adelaide, South Australia
On 08/02/2013, at 3:15 AM, "Billy Britton" <william(at)gbta.net (william(at)gbta.net)> wrote:
Bill
://www.matronics.com/Navigator?RV10-List
cs.com
matronics.com/contribution
tganster
Posted: Thu Feb 07, 2013 6:50 pm Post subject: alodine |
Bill,
You can find it at Pegasus racing supply in New Berlin, WI. They are on the net. I have half a container full left, The stuff is very concentrated.
Tom Ganster CLI (Getting ready for paint)
Sent: Thursday, February 07, 2013 10:45 AM
Subject: alodine
Bill
_________________ Tom Ganster 40778 Fuselage |
palark
Joined: 04 Aug 2010 Posts: 1 Location: LOXTON AUSTRALIA
Posted: Sat Jul 13, 2013 1:27 am Post subject: Re: alodine |
Patrick,
I am very interested in where you source your alodine and deoxidine. I am in Loxton SA.
Roger
palark(at)tpg.com.au
[quote="rv10free2fly(at)yahoo.com"]Bill,
Patrick
On 08/02/2013, at 3:15 AM, "Billy Britton" <william> wrote:
| Quote: | A while back I recall a thread about alodine and where to get it. This particular post I remember was about a powder form. I've searched aircraft spruce and cannot find a powder form of alodine. Can anybody tell me where I might find it? Also, Ive never done the alodine before. What prep is required of the parts before using the alodine?
Bill
cs.com
[b] |
_________________ Roger |
Posted: Sun Jul 14, 2013 12:17 am Post subject: alodine |
I initially sourced mine through John Johanson, however he's no longer in business.
Try Henkell and I think there agent is at Lonsdale here in Adelaide. Tell them you'd prefer the crystals to mix up yourself.
They also sell the Deoxidine phosphoric acid pre-etch.
You should purchase a box of 3M maroon scouring pads from Weber Abrasives here in Adelaide.
If you need any further information or ad advice, please call me (Mob: 0418 850 156).
Warm regards
Patrick
On 13/07/2013, at 18:57, "palark" <palark(at)tpg.com.au> wrote:
Patrick,
Roger
Patrick
> Thanks
> Bill
>> cs.com
> [b]
Roger
http://forums.matronics.com/viewtopic.php?p=404588#404588
