Posted: Mon Jul 15, 2013 1:40 am Post subject: Starboard flap pin doesn’t engage easy any longer †|
On 07/08/2013 06:13 PM, Neville Eyre wrote:
| Quote: | Hi Roland,
The ''eyeball'' ball socket is held captive by a ring [ collar ], if
the ring has moved outboard, it will allow the eyeball to swivel too
far, that is why the pin will jam in the hole.
What also helps is to use a bit of sticky grease ("white grease")
between the ball and the collar, and not moving the flap drive tube to a
different position when the wings are off. The ball will then stay in
the right position to catch the pin.
Before I had the sticky grease on but some teflon doped oil in it
instead, the balls turned with any movement and rigging was sometimes
very difficult.
Frans
