n100rh(at)sbcglobal.net Guest
Posted: Sun Jul 21, 2013 12:03 pm Post subject: RotaxEngines-List Digest: 8 Msgs - 07/10/13 |
A quick question for you all. I have a 912S in a Rans S7. Out of the
blue the oil pressure gauge is rapidly swinging from high to low
followed by a pause at the correct oil pressure. Then more of the same.
This only happens after flying for 20 min or so in 70F weather. I
figured it must be the sender unit which is attached to the block near
the oil pump. I got the same readings on the next flight. Reducing the
engine to idle causes the gauge to settle down.
However, here's where it gets interesting, I noticed that all the
gauges, tach, oil temp, oil pressure and voltage are stable at the
beginning of the flight but when the oil pressure starts to swing wildly
the other gauges too have started to vibrate, not to the extent of the
oil pressure.
I'm starting to become suspicious that the voltage regulator is getting
ready to crap out. Thoughts?
Ralph
Reno, NV
rickofudall
Posted: Sun Jul 21, 2013 7:00 pm Post subject: RotaxEngines-List Digest: 8 Msgs - 07/10/13 |
Check engine to airframe grounds and instrument grounds first.
Rick Girard
On Sun, Jul 21, 2013 at 3:02 PM, Ralph K. Hallett III <n100rh(at)sbcglobal.net (n100rh(at)sbcglobal.net)> wrote:
| Quote: | --> RotaxEngines-List message posted by: "Ralph K. Hallett III" <n100rh(at)sbcglobal.net (n100rh(at)sbcglobal.net)>
A quick question for you all. I have a 912S in a Rans S7. Out of the blue the oil pressure gauge is rapidly swinging from high to low followed by a pause at the correct oil pressure. Then more of the same. This only happens after flying for 20 min or so in 70F weather. I figured it must be the sender unit which is attached to the block near the oil pump. I got the same readings on the next flight. Reducing the engine to idle causes the gauge to settle down.
However, here's where it gets interesting, I noticed that all the gauges, tach, oil temp, oil pressure and voltage are stable at the beginning of the flight but when the oil pressure starts to swing wildly the other gauges too have started to vibrate, not to the extent of the oil pressure.
I'm starting to become suspicious that the voltage regulator is getting ready to crap out. Thoughts?
Ralph
Reno, NV
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
http://forums.matronics.com
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
Roger Lee
Posted: Mon Jul 22, 2013 5:25 am Post subject: Re: RotaxEngines-List Digest: 8 Msgs - 07/10/13 |
Hi Ralph,
I'm with Rick. Sounds like a poor ground. It could be a loose ground or a corroded one.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
